seawing 120a question.
  • kendt
    • Jul 2011
    • 557
    I notice the seawing 120 esc says it has over temp protection. Wondering if it shuts the unit down completely or is it a soft cut off.
    Just curious is all.
    • 5660
    Not trying to hijack , but mine kept running until the caps were bulged, the thermal protection never kicked in. I have a suspicion that by then something would have been damaged. The caps can be replaced, though.
    • kendt
      • Jul 2011
      • 557
      Is it a newer one? I dont recall seeing it in the specs before but I may have just missed it.I have one that seems to run fine for a bit but then just cuts off. I was wondering if the temp protection was doing it. I swapped it out for a new one and it works fine in the same set up.
        • 5660
        Well, I don't know, it was in a boat that I bought here but seems to be the later version because the telltale sign is how the blue cooling tube looks, the newer ones has only one rib where as the older ones there were two or three ribs on the pipe to grab the silicone hose. Mind you, mine would still work, but I changed a new one with the intention of replacing the bulged caps.
        You sure it's not the LVC kicking in?
        • kendt
          • Jul 2011
          • 557
          No i dont use the lvc normally.
            • 5660
            I see.
            • kendt
              • Jul 2011
              • 557
              Just noticed in the very last sentence of the trouble shooting section of the instructions. The over temp mode is a soft cut off same as lvc. Good to keep in mind when using the lvc protection.
                • 5660
                Thanks! I need to start reading those instruction!
                  • 4297
                  Yep,
                  That always helps to start with.
                  • kendt
                    • Jul 2011
                    • 557
                    I have read them a few times and still managed to miss that part
