Sprint Cat?
  • madmikepags
    • Aug 2012
    • 1371
    No problem other than when u turn the classic hatch around you get a very flat area up front that the motor can't go past. If you have tose packs look at the Mini Avenger, it's the same bottom as the sprincat and there's plenty of space to mount your packs in the sponsons. I've built 2 of these for my daughters because I have a bunch of those big 6s packs and I can move them around a lot for CG.
    We call ourselves the "Q"
    • Rumdog
      • 6667
      It's not too hard to make the turbine hatch water tight. I've done it on all 3 sizes of sprintcats. I prefer the rails. Also, like jay does, I run the packs on the tunnel floor. 6s 5000's may not fit there though, depending on hatch choice and brand of cells. Another good sport setup is the 1527 1.5d on 5s2p with a x452 or x455.
      • madmikepags
        • Aug 2012
        • 1371
        if you're running offshore you will need 10,000 mah and then they wont fit on the tunnel floor with the turbine hatch (I think) I'll check when I get home tonite and let you know. Yes its very easy to make the turbine hatch watertight. I think you're 1521 will work fine, My pMono weighs more than my Sprintcat and I use a 1521 in there and it's a missle.
        • kevinpratt823
          • Aug 2012
          • 1462
          Thanks, I know I'll have no problem closing in the turbine hatch, I just liked the look of the classic on backwards. That being said, I just sent Steven(he's ordering it for me) another email to order me both hatches, and I'll go from there(hopefully I can make it work so I can run either. As far as the motor/esc, I'm really looking to reuse what's in the Explorer, so I'm going 6s. Also, when I run, I bring several boats and batts, so I'm not charging at the pond, all my 5s(4 at a time) are booked for the Sniper 45".
          If I can't make something work with these packs, well then, Mark F will be hearing from me for some new dinos.
          All that being said though, I do already have a 1527 1.5d in my cart...........
          My private off road rc track
          • kevinpratt823
            • Aug 2012
            • 1462
            It's hard to ignore all the talk about how awesome and dominant the Sprint Cat is. Is the Avenger an the same level of performance? Or does the extra height hold it back?
            Steven does have an Avenger in stock.............
            • Heaving Earth
              • 1929
              I haven't seen the avenger 36 built or run yet, but I'm willing to put money on it that it would kill the Df cat
                I've seen the Team Believer run (same as the new Avenger 36 with a different hatch) and it is a good race boat. I can't compare it to the SprintCat as I've not seen the two run together, but I like the looks of the A-36 a lot. I too would expect the Avenger 36 to outperform the DF cat on an oval race course, but then I haven't seen both run together either. Here is my 6S SprintCat at Legg Lake a few years ago.
                • kevinpratt823
                  • Aug 2012
                  • 1462
                  I honestly don't think it means much that a boat can beat the DF Explorer in anything other than a straight line, my Explorer is only 11" wide and will not safely turn at speed, these other hulls are 14"-14.5" wide, they obviously will turn better and flip less. The Explorer is great in a straight line, I get 69mph(gps) consistently with just one Leo 4082, and Kieth Bradley has broken 100mph I believe but that is an apple, now I want an orange,......... and also maybe a new bananna(new hydro).
                  Also worth noting, OSE show the Avenger being 1lbs-4oz. heavier than the sprint cat..........
                  • Heaving Earth
                    • 1929
                    Go for the sprintcat
                      Originally posted by kevinpratt823 View Post
                      Also worth noting, OSE show the Avenger being 4lbs-4oz. heavier than the sprint cat..........
                      Better check your math........
                      • kevinpratt823
                        • Aug 2012
                        • 1462
                        Ha! I meant to type 1lb-4oz., somehow the 4 snuck in there, good eye!
                        • Speedracer128
                          • Apr 2013
                          • 288
                          @ fluid
                          That sprint cat looks sick
