I used single stage Summit Racing Urethane, but Krylon would be lighter in weight....although not as durable.
Whiplash Strut
Definitely not going to use spray paint. I know some people like epoxy paint and other like automotive. Not gonna paint anytime soon just looking at the options for what is the best for a boat application.Originally posted by detox View PostI used single stage Summit Racing Urethane, but Krylon would be lighter in weight....although not as durable.
I have the Sport 20 strut (first one) on mine. Keep this in mind too... This is only my opinion; the further away the prop is from the transom, the harder the motor needs to work to lift the boat. Your increasing the length of the lever arm...Originally posted by jfrancisco892 View PostWhich do you have on your boat?
Later,
Mike
In the first picture, isn't the strut fitted into the bracket the wrong way around? Surely the tapered end should be facing forward in relation to the mounting bracket.See the danger. THEN DO IT ANYWAY!!!
its an optical illusion. it looks like the back is the tapered side but its not. he has it right, as i have the same strutOriginally posted by 785boats View PostIn the first picture, isn't the strut fitted into the bracket the wrong way around? Surely the tapered end should be facing forward in relation to the mounting bracket.
Yes. But yours is fitted into the bracket 180 degrees the other way. That's all I'm saying. It is not fitted the right way round in the link photo.See the danger. THEN DO IT ANYWAY!!!
well then i dont know what photo you are reffering to, because the photo detox posted has the strut in the right direction. which photo are you talking about?Originally posted by 785boats View PostYes. But yours is fitted into the bracket 180 degrees the other way. That's all I'm saying. It is not fitted the right way round in the link photo.
The first link in the first post by the OP.
http://www.offshoreelectrics.com/pro...Sport-20-strutSee the danger. THEN DO IT ANYWAY!!!
He is talking about this picture:http://www.offshoreelectrics.com/pro...Sport-20-strutToo many boats, not enough time...
