3/16 " cable collet
  • urbs00007
    • Jun 2011
    • 826
    collet
    [QUOTE=grsboats;497788]Definitevely I second Martin/Tyler on the MBP collet and your timing is too much advanced for this motor(play with 3,75-5 max).I have seen some bad collets produce this problem with Leopard shafts.Also I think the X450 is too much prop for this set up..you can go in the mid 80's with a 1450 reduced to 44-46mm and 3,5 cup.Gill[/QU where exactly do you cut the prop to reduce diameter?
    • urbs00007
      • Jun 2011
      • 826
      where exactly do you trim the blade to reduce diameter
      • grsboats
        • 972
        All the mods I did on my props use prop duplicators that I've been making along these years of practice so it 's no that easy make a cut and say the prop is reduced in diam.You have to cut the trailing edge of one blade then make a mold of this mod and apply this pattern to the other blade, To reduce diam I use my lathe but you can do it with a dremel too.Be carefull to have simetric blades before balancing and sharpening.If youre not confident get a hold to Mark Sholung a great guy to deal with and you will have a fast wheel. Gill
        GO FAST AND TURN RIGHT !
        www.grsboats.com.br
