"Q" Outboard tunnel discussion. 6S motors and ESC's?
  • kendt
    • Jul 2011
    • 579
    #31
    My first set up using smaller prop and high rpm,s . So far i am super impressed.Got to be very gentle with the trigger though or it will wheelie like nobody,s business.The acceleration is amazing.
    • er8sr
      • Apr 2013
      • 183
      #32
      What kv is that motor and what prop you using?
      • kendt
        • Jul 2011
        • 579
        #33
        1900kv with a tfl 442 trimmed to 40mm
        • er8sr
          • Apr 2013
          • 183
          #34
          I finally got around to building me a vs1 with a k&b lower and a scorpion 4025 outrunner, I have ran it on a 4s fixing to go to 6s as soon my new seakings get here
          • HTVboats
            • Jun 2011
            • 936
            #35
            er8sr,
            What kv are you using? I have run a 4020 1350kv Hyperion/Scorpion on a .45 size nitro hull with an m445 prop on 6S. Just short of 50mph. Your 4025 is a tad stronger and will be a handful on your VS1. A rocket for sure.
            Mic
            Mic Halbrehder
            IMPBA 8656
            NAMBA 1414
            • er8sr
              • Apr 2013
              • 183
              #36
              Mic
              Sorry it is 4020 1390 kv out runner. Will be testing 6s hopefully thursday
              • HTVboats
                • Jun 2011
                • 936
                #37
                How did it run?
                Mic Halbrehder
                IMPBA 8656
                NAMBA 1414
                • er8sr
                  • Apr 2013
                  • 183
                  #38
                  Runs really good motor is nice and cool. Plenty fast going to gps it and play with props tomorrow
                  • er8sr
                    • Apr 2013
                    • 183
                    #39
                    Still playing around with motors I threw a Align 500mx motor on 1600kv a worn out 6s 4000 pack gps' d it @ 49.8 propped with 440
                    Boat is very effecient and fun to run I get a solid 5 minutes...
                    • kendt
                      • Jul 2011
                      • 579
                      #40
                      I did not have a good season with mine. The 7.5 outboard is too big, so for next season I will switch to the 3.5. I also had a ridiculous amount of trouble with esc,s so I didn't get a lot of running with it at all.
                      • er8sr
                        • Apr 2013
                        • 183
                        #41
                        Sorry to hear that, I tried my luck @ waterprooing a esc it worked really well till i flipped it and kept running then it went dead about 2 minutes later,I got another HS 45 with a K&B 7.5 lower i have a feeling it is way tio big Here is a pic of the VS1 wiht the Align motor and K&b lower
                        • kendt
                          • Jul 2011
                          • 579
                          #42
                          Ya the 7.5 is def too big. I had one so I thought i.d try. I tried a scorpion 3226 and found it was too small. Got fairly warm even with smallish props. The dr mad thrust 3674 1580kv looks like a good match but I was unable to get any real solid run times or try many props cause my t180 kept going into lvc. was unable to get it resolved. What kind of wattage does the align handle?
                          • HTVboats
                            • Jun 2011
                            • 936
                            #43
                            er8sr, Actually your picture is an OS lower which is the best of all. Your speed and run time are excellent.
                            Kendt a 3674/1580 on 6s should do very well. A Grim racer 42X55 or M440 on the low end and you should be able to handle an m445 on the big end.
                            Mic
                            Mic Halbrehder
                            IMPBA 8656
                            NAMBA 1414
                            • er8sr
                              • Apr 2013
                              • 183
                              #44
                              Mic
                              Iam Sorry. OS lower. ... I keep saying and Thinking K&B. Iam Very Very happy with the setup
                              • er8sr
                                • Apr 2013
                                • 183
                                #45
                                Kendt here you go
                                The 500MX is rated a 1600 W max, and 2300 W (5 Sec burst). If 1 Watt = 0.00134 HP, then the 500MX is about 2.15 HP.
