cant get new esc to work
  • maurice1287
    • Feb 2013
    • 27
    hi there, I just installed a 1800 leopard and a 180 seaking esc. I had two 2s lipos and they worked ok, but installed two 4s lipos and made the recommended adjustments with the programmer and can get the motor to start, any ideas? when I plug in batteries the esc beeps about every second, then I turn on the controller and the beeping stops and the esc flashes continuously. the rudder will turn but the motor no go, not sure what I've done.
    Are the 4s connected in parallel?
    • Alexgar
      • Aug 2009
      • 3701
      Please post some pics of your setups
      • maurice1287
        • Feb 2013
        • 27
        series. i'll try to send a pic in a minute
        • Alexgar
          • Aug 2009
          • 3701
          2 4 s in series is above that escs specs
          • maurice1287
            • Feb 2013
            • 27
            should change it to parallel?
            • maurice1287
              • Feb 2013
              • 27
              photo.JPGshould change it to parallel?
                Yes, be thankful that it didn't work, that ESC is nor rated for 8s !!!
                Sent from my Droid using Tapatalk 2
                • maurice1287
                  • Feb 2013
                  • 27
                  so parallel will work then? thanks for the help
                  • Alexgar
                    • Aug 2009
                    • 3701
                    Is test it with the 2 s and if it works count yourself lucky and build a parallel harness
                      I can't really see the photo on my phone, anyway, it can't be series, the ESC is rated to 6s max, it will not work beyond that. You ESC wire should not use another "bridge" as shown, too long and too complicate, I am sorry that I don't have A real keyboard to go into length.
                      • maurice1287
                        • Feb 2013
                        • 27
                        got it together in parallel. works now. I will tidy it up when I get some odds and ends at the hobby store. thanks so much for your help guys. just got started in fast electrics and my gosh, its awesome.
                        • maurice1287
                          • Feb 2013
                          • 27
                          just one more question, think I should add another pickup and provide a little more cooling? thanks
                            I am glad all worked out. Looking at your picture, if I may make one suggestion: the orientation of the ESC might warrant a reconsideration. The silicone lines are pinched a bit and I think your power lines ( ESC to Batt) are on oneside only, it might be easier if you turn it around. Here is mine, not saying that should be the only way, but I have no problem with water volume and I don't think you will need to add another pick up.DSCN3401_3602.jpg
                            I don't know what your set up is for connectors, but from the picture, you seemed to have bullet plugs and then some EC5.5, I would streamline the set up for this boat and ALL your future boats with the 5.5mm plugs. I use that every where , from battery to ESC to motor. A good parallel connector is found here:http://kintecracing.com/Home_Page.php about half way down you will see a "Y" shaped connector.
                            Enjoy!
                            • maurice1287
                              • Feb 2013
                              • 27
                              thanks so much for the info. I'm going to try and make it look more like the one you have. kind of don't realize what your doing wrong till you see some of the other experienced guys handy work. I'm sure I'll be back with more questions down the road..........thanks maurice
