esc pot temps
  • sansouci01
    • Mar 2013
    • 30
    esc pot temps
    I changed the timing in my impulse 31 from soft to hard. I wanted to see if there was much of a speed difference. I only ran it for about 3 minutes pretty much full out just to check the temps. Batteries,motor and esc were all cool but I did notice that the pots were a little warm on the esc. I never noticed if they were warm when the motor was set to soft timing. How hot is too hot for these things
  • Heaving Earth
    • 1929
    What's a pot?
    • Jeff
      • 233
      It's kinda a cousin to a kettle
      I try and avoid paste eaters.
        Pot, Are you talking about the capacitors ?
        If so there should be a number on them like 105*C tops.
        • sansouci01
          • Mar 2013
          • 30
          ok...ok...I feel stupid...yes,capacitors....I guess you might call them caps...not pots...don't be too hard on me...this is my first REAL rc boat
          • Heaving Earth
            • 1929
            Lol, ok well they get pretty warm. Mine have been up near 140 degrees before
            • sansouci01
              • Mar 2013
              • 30
              Another question. How important is balancing and sharpening the prop. I have the stock prop on my impulse 31. I never did anything to it. I'm thinking about getting a m445 prop for it. Seems like everybody likes those for this boat with the stock set up. I'm just doing runs on my pond so not racing it or anything. $15 for the prop and $25 to sharpen/balance is a little out of my budget...lol
                Very important to have good S & B props.
                • Heaving Earth
                  • 1929
                  if you cant afford to buy one s/b and dont know how to diy, then dont bother buying one. as lenny said its super imporatant. an out of balance prop will reek havoc on your drive hardware and cable
                  • 785boats
                    Wet Track Racing
                    • 3423
                    The Graupner carbon fibre props that Steve sells are pretty good if you aren't going to bother with sharpening & balancing props.
                    Or the CNC aluminium range. They both only need a slight tickle along the leading edge to sharpen them up a bit.
