55" Dumas Scarab build
  • anateus9
    • Jan 2013
    • 3
    I'm fairly new to building fast electric boats and I have a question for the experts out there...I recently got a 55" Dumas Scarab with a vintage Graupner Antreib M1984 outdrive on it. After some research I found the outdrive was the predecessor of the Graupner 820 series, but it's built like a tank. I took it apart, and it has heavy duty hardened gears with 8 mm shafts, full bearings, and the outdrive is rated (by Graupner) for 1.5 kW electric or 25 cc gas. It has a fiberglass 65mm 2 blade prop on it, pitch appears radical, but unknown.
    Now for the questions:
    Since this is a big boat (and I want some wow factor), would a Leopard 4074 (at 2.6 kW) be within reason? If not, what would be appropriate?
    Also, what prop would you suggest?
    Thanks for any help!
  • Heaving Earth
    • 1877
    for a 55' boat a 4074 is way too small. buy a castle 2028 or leo 56mm motor
    • anateus9
      • Jan 2013
      • 3
      Thanks for the insight, do you trhink the outdrive can handle that much power?
      • Heaving Earth
        • 1877
        i really cant say for sure on that sorry. someone who knows more than i will chime in soon enough im sure
        • iridebikes247
          • 1528
          There is a member on here make-a-wake he built this boat too. He is using a leopard 5692 1000kv motor
          There it is. I say run the outdrive till it blows up then convert and use something else
            • 4297
            Hears the modding thread he did,
            But his outdrive spun a gear or bearing went out on it.
            http://forums.offshoreelectrics.com/...-offshore-boat
            [ATTACH=CONFIG]96940[/ATTACH]
            • anateus9
              • Jan 2013
              • 3
              Thanks for the help. I'll post build pictures when I get all my parts together. I'm hoping the Graupner outdrive's gears hold up. I'm already planning to replacing the bearings even though the unit has never seen water.
