How to tell if the ESC is toast
  • macace123
    Robotics Operator
    • Mar 2013
    • 477
    is there a way to tell if the ESC is toast or test im running 2 2s 5000 mah 40C batterys and its a stock proboat 6s/80 AMP ESC and i keep frying the motor wires please help
    Its not the boat its the driver http://namba2016fenats.com/
    Whiplash,Sprint Cat, Pursuit, 83' Miss Rock modern hydro JAE21, Dragon M11 Tunnel, Mickey Beez Jet, CF JAE21
    • 9438
    What prop are you running and what is actually frying? Pictures? How long are your runs?
    • macace123
      Robotics Operator
      • Mar 2013
      • 477
      octura m445 no more then 4 min runs the white wire on the motor is brown. i know i need to up the connections size. is the ESC good or should i move to 120amp or 200amp. i cant keep frying anymore motors. this is the blackjack29
        • 5660
        Stock ESC should be good, you need to get 5.5mm bullet plugs between the ESC and Motor, that is the weak link usually, many times these come unsoldered, if you have temp gun, check it, will be surprised how hot the connection is!
        BTW, if you want to up grade the ESC, my personal favorite is the Seaking ( Turnigy) 180A ESC. I have that in my MG with a Leopard 4082/2200kv motor running 4s2p.
        • macace123
          Robotics Operator
          • Mar 2013
          • 477
          thank you this is my next move
            • 9438
            Good connectors as above +1.
