Miss Geico 29 V2 Neu 1515
  • Paciic Blue
    • Mar 2013
    • 44
    Hello every 1 ordered Neu 1515 2200kv and also have a T180 esc! I was wondering if any has done any testing with this set and what kind of speeds were they hitting ? My goal is at least 60mph .
  • Paciic Blue
    • Mar 2013
    • 44
    I forgot to mention Its running 5s
    • SirBudman32
      • Aug 2011
      • 609
      Run that same set up , only a castle 1515 2200 T 180 on 5s in a Genesis. Did mid 50s
      Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
      • stadiumyamaha
        • 1284
        You should be able to get mid fifties with that setup on 4s.
        2200kv on 5s is pushing it to the limits at over 40000rpm and may cause premature failure. Jmo
        • stadiumyamaha
          • 1284
          What hull is is in? And start with a small prop.
          • TheShaughnessy
            • 1419
            Possible as long as the drive line stays together and the boat stays on the water, be prepared to split your hull. I would add floatation if possible especially with the heavier 5 s packs.
            I was getting 55 ish on 4 s and a less efficient hk4074 2000kv with a m445. Slight chop really unsettles it. Likes ripples though
            • Alexgar
              • Aug 2009
              • 3522
              Mid to high 50s in an apparition t180 cc2200 on 5s x645 running real loose and watch temps a hot setup somewhere in saw territory
                • 5660
                You are going to love that motor! When I was building my Mean Machine, the member whose build I was modeling after had his Neu 1515 on 5s and was hitting high 50's with a m440 prop. These motors are more efficient than Leopard for sure, I am running it in my MM and loving it, although I run 4s2p with a bigger prop, m445. My MM ran neck and neck with my MG ( Leo 4082/2200kv, x642) which is GPS'ed at 53.5 mph.
                Watch out for prop size tho.
                BTW, here is the boat that has the 5s2p set up that I was talking about:http://www.youtube.com/watch?v=mjEqH...ayer_embedded#!
                Last edited by tlandauer; 04-03-2013, 01:18 AM. Reason: English and wrong info on prop
                • Paciic Blue
                  • Mar 2013
                  • 44
                  Mg v2 29"
                  Im running that set up in the MG V2 29"
                  • Paciic Blue
                    • Mar 2013
                    • 44
                    What kinda batteries were you running ? I still have the all stock set up in the boat and I am not even hitting 40mph.
                    I have the 2 X 5300 7.4v 35c Thunder packs with a X642 s/b , the strut is level on the top of the mounts and the batteries are about 1 1/2" forward drom the transom
                    My CG is about 30% , I hear alot of people like that prop but for me I just cant seem to get it moving.
                      • 5660
                      I used Sky Lipo, 4s, 5000mah and 40C. For my GPS run I was using x642, never GPS'ed with m445.
                      I have to apologize for bringing up the Mean Machine only because you said you wanted to run 5s. I agree with Stadiumyamaha that if you run 5s, start with a small prop such as m440.
                      My MG V1 started with the Leopard 4082/2200kv, so I don't know how the stock one runs, but your speed is consistent with this boat in stock RTR form, I think.
                      • TheShaughnessy
                        • 1419
                        X642 is kinda small for the 1500kv motor on 4s, especially with the tounge slowing it down. Need more prop and/or rpm to get into the 40's.
                        • Heaving Earth
                          • 1877
                          If you put your boat on a table, how high is the strut?
                          • Paciic Blue
                            • Mar 2013
                            • 44
                            The strut bottoms out on the table.
                            With the X642 at this exact set up I got up to 39 mph . I started about a 5mm up from the mount to back to even with the top of the mount and 39 was all I could squeeze out of MG now I am at the same place with anX442
                            • Paciic Blue
                              • Mar 2013
                              • 44
                              Im trying to attach a photo but not sure how
