Help choosing motor mount.
  • BradB
    • Mar 2013
    • 5
    Hi, new member here. New to electric boating. I used to race gasoline boats a few years back. Got into airplanes and helicopters, and have gone pretty much all electric on those except for a couple. Decided to build an electric boat to run at the pond where we fly. Ordered the Whiplash Sport 20 from Blazer Marine. Looking at running a sport setup with the UL-1 motor and ESC. Started looking at the motor mounts on OSE and am lost as to which one(s) will work best in this setup. Any suggestions?
  • Heaving Earth
    • 1929
    Not sure how much room you have in there but I use etti mounts these days. They're super adjustable and can accommodate a large number of different motors. I like this because sometimes I like to swap motors and try new things
    • siberianhusky
      • Dec 2009
      • 2206
      Just finishing up the exact same build, I like these mounts personally, used them a couple times now.
      http://www.offshoreelectrics.com/pro...prod=etti-h010
      The side plates are longer than the 13$ mount, more contact area for glueing.
      Don't need the rear support with these short can motors.
      I don't think the water cooled mounts do much of anything, have one in a cat, my data logger shows almost no difference in temperature with or without water flowing through the mount. Might do something if I installed a 3rd water pickup! I had the water going through the water jacket then into the mount, probably too warm to make much cooling difference at that point.
      Just read the above post, I don't have or plan on using the Blazer cowling, I don't think it will be a problem, I'm not 100% sure though!
      I'm running my battery right in the nose.
      • BradB
        • Mar 2013
        • 5
        Thanks. That one looks pretty versatile. Waiting for the kit to arrive so I can see what kind of room I'll be working with.
        • electric
          • 1973
          Agree. These are great mounts, Cheap, adjustable(love that) and great for smaller motor set ups. I am even used one with a Neu1515 (with some grinding of the mount holes) and it worked fine.
          • jstolz
            • 377
            I have the same mount that siberianhusky recommends in my P-Limited Offshore boat. It's a nice mount. For my P-Limited Sport Hydro Whiplash, I made a wood mount. If you wish I will take some pictures of it.
            Jay
            • BradB
              • Mar 2013
              • 5
              Jay
              Yes, please take a picture if you don't mind.
              Also, what size flex shaft should I be running on this size boat?
              • jstolz
                • 377
                Brad,
                Here are a couple pictures of the Whiplash.
                I used .150" flex cable.
                Jay
                • BradB
                  • Mar 2013
                  • 5
                  Thanks for the pictures. That is always an option too. I think I'm going to try the etti mount first and if there are problems with fit I can make my own.
                  • Heaving Earth
                    • 1929
                    Do you mean the 1520? The 1515 should fit without mods
                    • electric
                      • 1973
                      No, it was a 1515. I think some of the older 1515's may have had some slightly different screw patterns. I seem to recall some conversations about that.
                      • BradB
                        • Mar 2013
                        • 5
                        Never mind on the shaft question. Realized the hardware I got from Blazer is for .187 shaft so I ordered all of the .187 driveline hardware.
                        Just placed an order on OSE for everything else I needed except the ESC, cooling shroud and prop. Want to get a little beefier ESC so I can experiment with other power setups down the road. Would prefer an ESC with data logging. Should at least have everything ordered now that I need to get the boat built and painted.
