Collet Problems
  • Gary
    • Jan 2009
    • 1104
    It wasent the flex that I thought was sliping but the collet at the motor shaft that was. Either way looks like another dead speedo.
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
    • jsturess
      • Jan 2013
      • 38
      Hijack or not, sorry!
      Can some one please till me if this collect can be used with leo 4082 and ose-80610 motor mount?
      I know that the MBP collect will not fit in front hole of the motor mount (80610=14mm and collect 18mm in diameter)
      So the question is: Is the motor shaft sufficient long to install/use the MBP collect in a correct way?
      Regards Johan
      • Gary
        • Jan 2009
        • 1104
        Well this much I can tell you. I had to install the motor ,back it up a little ,slide the collet on ,bolt motor to mount, then tighten the collet down. Will not fit through an OSE aluminum mount and will have to be disasembled the same way if the motor has to come out.No big deal though.
        Chris Craft 16 mph
