Bending Stuffing Tube - Stainless or Brass?
  • FE-Speedboats
    • Aug 2012
    • 54
    Hi Folks;
    I am near the end of my @build@ of a K&B 3.5 outboard leg conversion to electric. Everything I read tells me to ditch the teflon stuffing tube and use metal. I am wondering if I should use brass or stainless steel tubing? The cost difference is negligible. Is stainless easier to bend? Is there any other reason I should use one over the other?
    Thanks,
    Graham Humphrey
    FE Model Boat Racer; Q-mono, P tunnel, P hydro (cat).
    IMPBA D-1
    20844 S
  • photohoward1
    • 1781
    No need for Stainless. It can be brittle too. Brass is what everyone uses.
    • Chilli
      • 3204
      Hey Graham. Brass is easier to work with and will be plenty durable.
      I read on the gas board that a race pond was lost in Ontario. Do you know anything about it??
      Mike Chirillo
      www.capitolrcmodelboats.com
      • BHChieftain
        Fast Electric Addict
        • 2051
        Brass is also used in bushings and sleeves, where there are dissimilar metals rubbing together. It "gives", and in the bushing case, self lubricates. I bet the brass stuffing tube would provide a smoother drivetrain than stainless, but I am just speculating...
        Chief
        • FE-Speedboats
          • Aug 2012
          • 54
          Hi Chilli
          I've only heard rumblings about London losing it's pond, but then I also heard they may have a new one?? Anyway I am not the expert on that so you'd better ask Mike Hallam or someone from Thames Valley Model Boat Club.
          Graham
          IMPBA D-1
          20844 S
