Octura under hull strut
    Anyone have or know where I can get one.I have this animal that I want to add it too
    This is the setup now
    • paultbg
      • Mar 2012
      • 112
      @srislash- you can try one from here :http://www.ebay.co.uk/itm/NEW-RG-Rac...item4170db49eb
      they are very good, tested in maaaaany years of IC racing.
      • jstolz
        • 377
        I may be able to help you. I have a Atlas Van Lines 40 nitro boat and converted it to electric. It had a sub surface flex drive. The boat is now a 10th scale boat with a wire drive. I'm using an Octura strut and mounting bracket. It is not a sub surface strut. I mounted the bracket inside of the boat with the strut going through the bottom of the hull. The setup allows me to make slight angle and depth adjustments of the strut.
        I will take some pictures and display them. The boat is beautiful. Is it a scratch built or a kit?
        • mtbenjamin77
          • 885
          The nitro scale and sport hydro rules requires you to run the strut under the hull, Just simply mount the strut on the inside facing of the bull bottom. Cut a slot to slide the strut through.This allows adjustment of trim and height. Tape it up on the inside until you get the right adjust ment then seal with silicone
            I look forward to seeing what you have got there J...
            • jstolz
              • 377
              Here are the pictures of the strut in my 10th Scale.
              Jay
              • Richie the shipwright
                boatbuilder
                • Dec 2012
                • 185
                Man thats a really sweet model... bit of a change in pace for you tho mate?? Are you unwell? :-)
                Im confused..... no...wait...mabee im not?
