Syncron or canoe?
  • Piranha2
    • 320
    Syncron or canoe?
    hey everyone, a couple quick questions, if you all don't mind.........self-righting or retrieval?......deep vee or cat?.......27-32" or 39-42"?.......ABS plastic or fiberglass?......epoxy glass or carbon fiber?........brushed or brushless?........direct drive or transmission?........AM or FM?........ugh!.......see what 5 min. talking with Steven will get you?......obsessed with RC boats.......my significant other thanks you!
    • 7990
    What do you want to do with the boat? How large a pond do you run on? Are there other R/C boaters in your area? What types of boats appeal to you? Do you have any other R/C experience?
    Give us a little more information and we can be of more help. Welcome aboard! :D
    • ReddyWatts
      • 1700
      same
      These are my preferences: Cat, fiberglass, 32-38", 13XL-14XL, direct drive, FM. Everyones is a little different. Thats what makes this an interesting hobby. Finding your own.
      ReddyWatts fleet photo
      • SJFE
        • 4735
        My prefrencees are the same as Reddy's with only one diffrence. I prefer DSS to FM. Not hainvg any backround on what you have, where you run or if you run with buddies or alone..I sugest a SuperVee for a first FE boat. If you decide this isent for you..the resale is good. You will recover @ least 80% of the investment.
        • Piranha2
          • 320
          hmm.....sport boat, little RC experience, decent size ponds, 2 or 3 of us chase each other around with minimal crashes and I like an original sounding boat. My Caribbean Cruiser 2 sounds cool on plane and the SW26 sings on 7 cells. Now a 38" fiberglass cat with a 14XL and FM ??? ouch! You're talking serious cash. Although I do like the H&M Maritmo 36" cat. The things with the cats are you have to worry about 2 hulls instead of 1 and that flex drive tube hanging down in the middle....deep vee with direct drive seems the simplest, strongest and least expensive. BTW 20-25mph seems fast to me........especially after 2 runaway incidents that ended up on shore out of range.
          • ReddyWatts
            • 1700
            The 14XL boat I mentioned cost me $800, but you can build a brushless for about $450 from scratch using budget parts.
            • SJFE
              • 4735
              Buy a SuperVee and a 42mm carbon fiber prop right here fome OSE. 28mph and the 42mm prop will run stable. Buy an entry level FM and your run away problems will be a thing of the past. You will be more than happy.
              • Piranha2
                • 320
                Thank you for the help guys.....I do like the Supervee but like everyone else I want something original....and $450.00 sounds reasonable for brushless. Any hints? or am I on my own? I guess the supervee set-up for $159.00, an FM for $75.00, and a Syncron with flood chamber and hardware for $450.00.....hmm sounds like $700-$800.
                • ReddyWatts
                  • 1700
                  same
                  BPHobbies controller 80 amp $50.00
                  OSE 540 / 12XL $69.00
                  OSE X440/??? $12.00
                  OSE .150 3/16 drive cable $4.99
                  OSE 5mm - .150 flex coupler $9.95
                  OSE .150-3/16 drive shaft $3.99
                  OSE Strut/rudder $70.00
                  OSE hull $150.00
                  OSE FM/radio $80.00
                  Total $449.93
                  • Piranha2
                    • 320
                    RW.....thanks for the info.....the titan 29 hull sounds like a good choice.....not too much for a beginner to build a boat?
                    • Mich. Maniac
                      • 1384
                      Im a little bit ahead of you, and as everyone will tell you everyone has their own preferences. I used a cheap 36" deep v and as soon as I opened the box I ripped everything out of it and started desiging. These guys on here have awesome boats inside and out. Mine probly wont look that good but I like working with the plastic and love the hull I have chosen. About 3 weeks ill tell everyone how it turned out!! but for the money I now have about 300 in it and just need one more motor and esc's.
