Twincat Flex Change
  • Mecka1990
    • Aug 2012
    • 180
    Twincat Flex Change
    hi, i got a zonda 41" TwinCat and want to change from the stock 3/16 squaredrived system to a 1/4 lex cable with 3/16 end for the prop, dont want the problems with the teflon liner any more, only get big resistance and vibrations out of it, wayne how much i change them, i found here this flex: http://www.offshoreelectrics.com/pro...?prod=ose-1290
    Now the Question is where i can find the Reverse one? Maybe someone already changed from 3/16 flex, 1/4 drive shaft in the stinger with 3/16 prop end to a 1/4 cable and give me some advise?
    i hope im not wrong, my 3/16 flex with squared end goes into a teflon liner and then into the brass tube, so i think the teflon liner is 1/4 and the brass tube is a 9/32?
    i fixxed the vibration and resistance that the zonda sometimes got with the flex by changing the teflon liner, but only on one side, the other side wont get fixxed by changing the teflon or bend a little bit up and down the brass tube, thats why i want to change the 1/4, hoping get a clean run, and changing to a bigger flex.....i think thats a good idea when i go for a saw build, what you think guys?
    Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100c
