Pissed and need to vent
  • Doug Smock
    • 5359
    Originally posted by JimClark View Post
    Thinking I am goign to fill it full of water and bleach about 1/2 full and let it sit for an hour or two then let it dry out and rip the insides to shreads
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • NativePaul
      Greased Weasel
      • 2770
      To be fair, that looks like laser cut wood which means RTR to me, as its newbies that buy RTRs you can't really blame him for letting it get in that state as he wouldn't have known any better (maybe for selling it like it, as it is pretty grim). If you built a wooden boat or put wood rails in a boat you wouldn't dream of not giving the wood on the inside a coat of epoxy as anyone htat has been in the hobby for some time knows its going to rot otherwise, I say name and shame the MFG for letting one with unsealed wood get out of the factory, hopefully its a rare QA issue and they will give you a replacement.
      • JimClark
        • 5913
        I bought it used I should have checked it out better. Not naming or shaming someone for something I could have averted. Just really wanted a Cat as opposed to a mono so I bought it.
        going to rip all the wood out put new glass in the bottom, Two part foam in the nose and work up something for some sort of battery tray to fit into the sponsons. Also reinforce the hatch cover with glass.
        Jim
        Billy Graham
        • TheShaughnessy
          • 1461
          At least you didnt lose a spec Fe 30 on the maiden run. Just remember it could be worse.
          • JimClark
            • 5913
            yup you are right it could be worse
            Billy Graham
              Yep, I was looking at that one to Jim,
              Looks like it was run in marshy waters and put away wet a lot.
              I still have to see what I have to do to the one I have coming.
              • Namba328
                Factory Team Pilot SPP
                • Jul 2011
                • 1229
                OMG what happened????
                Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
                Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
                • monojeff
                  • Nov 2010
                  • 2728
                  Jim things happen for a reason.
                  It's better this way because now you'll build it to last!
                  OSE GIFTING ELF
                  HAPPY HOLIDAYS!!
                  • mtbenjamin77
                    • 885
                    I always try to look at it as the glass is half full instead of half empty.
                      So sorry to hear that Jim, I hope after the bleach you can start at least on clean FG to rebuild. Doug is right though, it is not good to inhale that stuff. I would get a hazardous rated mask when cleaning it.
                      Good luck with the rebuild, I do think that you will be happier after the thorough rebuild, I know how meticulous you are, I am the happy owner of two of your fabulous hydros.
                      • Darin Jordan
                        • 9446
                        Jim,
                        That sucks... I had the same thing happen to an AquaCraft ProFisherman bass boat in the past. Stripped it out and soaked the whole hull in a bucket of bleach water overnight, then dried it out really well and coated all the wood with epoxy. Fixed the problem.
                        I don't think it has as much to do with the water you run in as it does with where the Chinese sorced wood originated from and how it's prepped for install.
                        NONE of my RTR boats get put into the water prior to getting this treatment now, even though the factory seems to be trying to coat the wood with something these days.
                        I think PB is looking at reducing the use of wood inside of these boats in the future designs. They don't like it and think it makes the boats look cheap, and I don't like it because it just adds weight that is more than likely unnecessary in the first place. Motor mounts and servos can be mounted to the hull, as we've done it for years.
                        Let me know when you get her cleaned up and ready and we'll get it setup.
                        I'm thinking of taking all of the wood out of one of my PB Cats and setting it up that way just to see if the hull itself is rigid enough to still hold together without the extra structure.
                        Sorry you are experiencing this... sucks...
                        Darin E. Jordan - Renton, WA
                        • JimClark
                          • 5913
                          Think I will try Darins repair suggestion first before I rip it out though the battery trays are coming out for sure as one is falling apart.
                          Billy Graham
                          • JimClark
                            • 5913
                            seller contacted me and we worked out a solution that I am happy with.
                            Jim
                            Billy Graham
                              If you are planning to run it in a spec class, try to weigh it before and after changes. I gutted a MG and used CF & epoxy inside with water cooled motor mount but, still it's a bit heavy. Stable as heck but, wish I kept it lighter.
                              • JimClark
                                • 5913
                                Ray what weight CF did you use. Got any after gutting any pics? What did you do with the battery trays?
                                Billy Graham
