I'm having a little bit of a conundrum, hopefully someone has some good advice for me to help me solve this issue.
All numbers below are just examples, not the true numbers I'd be working with but they are ones that provide easy math...
Let's say I have two 3S 5000mAh batteries running in series, so running at 6S with 5000mAh. At 22.2v, it would spin my 1000kv motor at 22000 RPM.
Now if I have two 2S 5000mAh batteries running in series, so 4S at 5000mAh... and so it's 14.8v and I'm using a 1500kv motor... that would also spin at 22000 RPM.
So here's my question... is there any benefit to one setup over the other? This would be for a catamaran, like a 29" Miss Geico or one of the other similar bodies. But to me, that doesnt really matter... I'm just trying to find out if there are any advantages of going with 6S over the 4S? Will one run cooler? Will one need a bigger ESC? Would both draw the same amps to spin the prop at full speed? Something tells me that a 6S at 5000mAh is going to run longer than the 4S at 5000mAh, but I'm not sure why I think that.
Any advice you can give would be great, it will definitely help me in making my future purchases!
