Esc suggestions
  • SpeedFreak_86
    • Jun 2011
    • 203
    Esc suggestions
    I'm running a Leo 3674 2200kv motor on 4s, I need a small powerful esc bc space is very very limited. What do you suggest?
    Slow and steady isn't my pace
  • Heaving Earth
    • 1929
    T120
    • jkr
      FE Addiction
      • 582
      Originally posted by Heaving Earth View Post
      T120
      And timing @3,75
      • SpeedFreak_86
        • Jun 2011
        • 203
        Is the avalible on ose?
        • h2o 1
          • Sep 2011
          • 854
          What type of hull,hydro,mono,cat?? Whats the lenght? Mono hulls will draw more amps than cats or hydro's due to more surface area in the water.
          • Heaving Earth
            • 1929
            Maybe, or kintec, or hobbypartZ sometimes has them cheaper than both.
            • Basstronics
              • 2384
              http://www.offshoreelectrics.com/pro...er-seaking-120
              • TristanJones
                • Oct 2012
                • 266
                http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
                Ive run one of these before, they are good, just be sure to make sure the barb fittings for the water lines are held in and sealed with loctite.
                Any more than 4s will kill the BEC eventually. (mine did anyway)
                  Free shipping.
                  • martin
                    • 2881
                    The T120 & Seaking 120 are the same esc.
                    • SpeedFreak_86
                      • Jun 2011
                      • 203
                      It's a tunnel hull, thanks for all the links!
                      • martin
                        • 2881
                        You also need to watch things with a 120a esc with that motor, theirs not much headroom. You have to watch run times & prop sizes personally id go with a higher amp esc.
                          Just add some caps,
                          I have been running one in my 36" Pro boat shockwave.
                          T120a with 0ne added cap and a 4074 2200kv on 4s with a x646/3 prop and gps at 45mph and nice run times,
                          Also run nice and cool.
                          • Heaving Earth
                            • 1929
                            I use seaking 120 in a 29" deep v with 3674 Leo 1700kv on 5s2p with x444 prop. It's a wide heavy boat and I have no problems with esc for two years now....
                            • Heaving Earth
                              • 1929
                              Just my experience tho
