Did I over-prop a 9XL with a m545 or did my motor overheat due to the choppy conditions?...
I had a very unusual run - after 3 minutes of running under windy and choppy conditions, my Mean Machine slowed down to almost a stop on the lake. After 1 minute, I regained throttle, but only about 30 seconds. The boat was moving very slowly again even with full throttle. So I bought it in...
No binding in the HW. The ESC and 4S LiPos were just warm to the touch, but the motor temp was hot. However, the motor mount and flex coupler were so hot that the water from my hand sizzled. The motor has run only 6 times with an m440, x442, x445 with no overheating issues. This last run was with a m545.
I am trying to determine if the chop had anything to do with the motor overheating where the hull was in mid-air half the time. I am wondering if the current peaked because of the bouncy chop or if the m545 was just too much for the 9XL? I thought that 9XL and m545 combination would be ideal?... I don't know if the motor is history now that the magnets have overheated?... If it is, then it's time for a Neu 1515/2200kv!
Setup: Mean Machine Hull, Speedmaster HW, 9XL-1853kv, 4S2P/8200mAh/15C, m545
However this is a quote from another thread: imagine a bunch of spikes in amps and voltage one after the other... that would generate heat in the best of the motors.
the throttle from rest. The startup spike reached way too many amps. I've since learned to get on the throttle easy. Eliminates those embarrasing wheelies/backflips
