Do you have experience with those motors ???
  • Alfa Spirit
    • 2131
    Hello everybody, do you have experience with SUXFLY motors? They look very similar with Leopard,
    Many motors at HobbyKing are Suxfly motors. If I had the money I bought a set of NEU Motors but this not my situation. Well I hope that I won' t be disapointed with those Suxfly motors...
    If you run those motors, please give me your advice.
    SUXFLY 4092 Series
  • iamandrew
    • 574
    I thought you had allready bought them?
    • Alfa Spirit
      • 2131
      That' s right Andrew and I want to know more about those BL motors.
      They look hi-end motors with HRC water jackets and Minimeca motor mounts but are they good enough??
        • 7277
        When you install them and run them, you can tell us how they are.
        • Alfa Spirit
          • 2131
          Yes but don' t know an other boat to compare... And with 37 Volts on each motor and 34400 RPM unload I will have the power or the fire
          If some people run SUXFLY motor, 3674 or others give me your advice, thanks
          • Rumdog
            • 6453
            The only way to find out is to build a boat, and run it.
            • Heaving Earth
              • 1877
              :tick:tock:tick:tock:
                • 7277
                Sometimes you have to dive in the water to see how cold it is.....
                • Eyekandyboats
                  • 1921
                  Send them to me and I'll tell you how they run gladly.
                  EYEKANDYGRAPHICS
                  www.rclipos.com
                  • iridebikes247
                    • 1528
                    If you're worried run them on low voltage first then check to make sure everything is ok before going to HV.
