So I seach google and most threads r about how crapy the company is and I think there out of businesses? However I bought a used Blast and it has a g freak brushed 12v 35a. Stage 1 esc. Does anyone know the specs? Can it handle 2-3 s lipo? Is 35a peek amps?
g freaks esc question
Arnie.
I've got a few different types of brushed ESC that state 12V max voltage & I have run them all on 3s lipo with no problem. I would say that your ESC will handle 3s too. They usually build in a bit of a buffer on the voltage & the 0.6V over 12v that a fully charged 3s pack has at 12.6v will be within that buffer. As soon as you apply a load the voltage will drop below 12V.
Of course the trick is to make sure that on 3s you use a prop that will draw less than 35A. The prop being used for 2s packs will probably be too big for 3s.See the danger. THEN DO IT ANYWAY!!!
