Stripped set screw
  • gfm1135
    • Aug 2012
    • 177
    Stripped set screw
    Anybody have a trick for removing a stripped set screw on a collet? Thanks
  • stadiumyamaha
    • 1371
    I've been able to drill them out with a good split point drill. Collet may be ruined afterword though.
    • MAMBA2200
      I need a scooby snack
      • 1347
      i drill a hole through it and use a easy out Works Great!!!!!
      • iamandrew
        • 576
        If your collet is still attached to your motor, you might wanna tape it up with masking tape, just incase any small peices of metal get into it when you try and cut it off etc
        • iridebikes247
          • 1669
          good point iamandrew, I had to drill one out once and filled a t600 outrunner with metal shavings. Took quite awhile using masking tape and putty to remove it from the motor.
          • sundog
            Platinum Card Member
            • Feb 2009
            • 940
            A left hand drill bit will sometimes back it right out.
            Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
            • johnnywall
              • Nov 2010
              • 34
              Good tip sundog.....I bet a sharpthreaded screw held in a drill on reverse...might grab it and back it out too. There is also some 19.95 for a limited time only!!! late night tv infomercial thing that is designed to remove stripped anythings.
              • Heaving Earth
                • 1929
                A left hand drill bit? Those actually exist?!?!
                • sundog
                  • Feb 2009
                  • 940
                  You bet. http://www.harborfreight.com/13-piece-left-hand-drill-bit-set-95146.html
                  https://www.youtube.com/watch?v=Qk2vFHu4jeo
                    I have a set of this: http://www.amazon.com/Alden-4507P-Gr.../dp/B000Q60UOO I have sucessfully removed set screw from pinion gear in my 1/10 electric buggy with this, it takes a bit to figure out which diameter to use (set screw was 1.5mm dia.)
                    This box has four different sizes but the smallest ( #1) should work. They are simply labeled as #1, 2, 3, 4, no specific diameters labeled.
