Outrigger motor temps
  • Lakefrontlivin
    • 232
    Just finished running my outrigger for the first time.. Only ran it for about a minute to see how it went..
    A little rough out there.. Couldn't go over 1/2 throttle at most for short bursts.
    It ran good when I could push it.
    Brought it in and checked temps. Motor was 120*, ESC was 130* and batteries were 110*
    Is this pretty good considering I wasn't running full throttle?
    Next question..
    I want to see how much was drained out of my Lipo packs..
    I have a Hyperion Duo charger and can do both packs at the same time. What do I look for on the next charge. ?
    I know I'm supposed to see how much I put in them..
    How do I go about doing that?
    Thanx, Tom H.
    Boat was verrry Quick for a little outrigger !!!
  • Eyekandyboats
    • 1935
    when you charge with your DUO it shows the amount of MAH that has gone into the cells.
    that is how much you used.
    EYEKANDYGRAPHICS
    www.rclipos.com
    • Lakefrontlivin
      • 232
      Thanx for the response..
      What page or screen would this be on if you don't mind..
      Thanx,
      • Eyekandyboats
        • 1935
        it should show up as soon as you start the charge.
        EYEKANDYGRAPHICS
        www.rclipos.com
          Tom, it's really difficult to tell much considering the use of part throttle, the rough water and the 60 second run. None of those temps are bad at all, considering. Once you are finished charging - not when you start - the charger screen that is up should show the amount of mAh put into the cells - my Hyperions do anyway. You actually took out a little less than the charger shows, but it is pretty close. Way to go with the little rigger!
