rigger
  • RaceMechaniX
    • 2825
    Very cool, sorry about the name but it's been 20 years since I saw the add in the RC Car action buyers guide or the boat buyers guide.
    What can you fit motor wise without having too tight of a bend radius for the drivline?
    TG
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • urbs00007
      • 826
      rigger
      tyler, i think i can put motor and esc in front compartment ( motor to the left ) and battery behind bulkhead. If I cant how tight a radius can I run cable ? thanks
      • RaceMechaniX
        • 2825
        For a 3/16" cable I would recommend no tighter than 6" radius. If the motor and esc were in the front compartment the bend radius is not a problem. If it were in the rear compartment, I would just check before cuttnig any holes.
        TG
        Tyler Garrard
        • grsboats
          • 972
          4082 2000kv,esc Turnigy 180 and nanotech 45C 6S produced speeds in the mid to high 80's on my previous Jae Fe so you can expect good performance with your boat too.1450 (45mm cup 3,5) 85mph ABC 52X70 88mph. Gill
          GO FAST AND TURN RIGHT !
          www.grsboats.com.br
          • urbs00007
            • 826
            rigger
            thanks guys. any problems with the swordfish 200 ? seems like a good fit with my boat.
            • grsboats
              • 972
              here is this same combo in a Jae Fe.my experience is with the SF 300 but for this motor the 180 is more than enough.
              www.grsboats.com.br
              • urbs00007
                • 826
                rigger
                is the seaking 180 same as turnigy 180 that ose sells?
                • grsboats
                  • 972
                  yes.
                  www.grsboats.com.br
                  • urbs00007
                    • 826
                    rigger
                    gil, just ordered the 4082 3d 2000 kv. would you say it has more power than a picco 45 stock ?
                    • grsboats
                      • 972
                      Yes ......It has 4,7hp and can be compared to a good nitro 45 engine running in the 40K depending the set up.Gill
                      www.grsboats.com.br
                      • LOVE6S
                        • May 2012
                        • 521
                        http://youtu.be/ym0vOQDDbIc
                        Is that rigger a JAE 21?
                        • grsboats
                          • 972
                          it's the Jae Fe amost same boat as Jae 21.The main difference is the hull height on the Fe version.Gill
                          www.grsboats.com.br
                          • martin
                            • 2869
                            Hi Gill, hows the new carbon boat. Have you run it yet. Martin.
                            • grsboats
                              • 972
                              Hi Martin yes I did few tests with the Leo 4092 on 8S but figured out that a Neu motor would be the ticket to reach my goal. The Neu 1527 1D just arrived and I will need to make some adjustements to get the boat ready and as soon its done will post a video.Thanks Gill
                              www.grsboats.com.br
                              • martin
                                • 2869
                                Gill are you going to be running the 1527 1D on 6s. Martin.
