rigger
  • urbs00007
    • 857
    rigger
    want to convert .45 nitro rigger to electric. are there charts to do this ? if not ,any suggestions?
    A .45 glow engine usually corresponds to a 6S setup. What is the length of the boat? Since the tub needs to be completely sealed, the tub's dimensions may determine the cell count. What is you budget and FE experience level?
    • urbs00007
      • 857
      rigger
      cheap , but dependable. 2 years exp. running 2230 on 12-s in a rigger close to 100 mph.
      • carlcisneros
        • Jan 2010
        • 1237
        also check and see if the batteries will fit in the area where the 45 was located.
        • urbs00007
          • 857
          rigger
          why cant i run the electric motor where the nitro motor was?
          • siberianhusky
            • Dec 2009
            • 2206
            I converted a JAE from nitro to electric, to get the cg correct nothing was located in a nitro setup location. The motor wound up in the former radio box!
            You pretty much have to get all the electronics motor included and move things around until you get a functional setup with the correct CG.
            In my instance the boom tube spacing was just plain old wrong! Should have removed the rear tube and relocated it then made new sponsons.
            You might get lucky and everything works out right with your boat.
            • chris
              • May 2007
              • 122
              My 6 S setup contains neu 1527 1.5 D and two battery’s ( 1500 grams) in front part of rigger
              Putting weight upfront of motor will change your CG, so motor goes toward back to compensate.
              Chris
              • urbs00007
                • 857
                rigger
                on 6-s what leopard motor and kv would be a good choice? with a picco 45 20 years ago boat ran 83 mph in oval trim. how much esc will i need?
                • Namba328
                  Factory Team Pilot SPP
                  • Jul 2011
                  • 1229
                  whats the length of the rigger and do u have any photos?
                  Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
                  Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
                  • urbs00007
                    • 857
                    rigge
                    hull is 33 " long 4 " wide 2.125 " high
                    • grsboats
                      • 1011
                      The last time I saw a similar rigger was in boat modeller magazine many years ago.You can convert it to Fe but take care as it is an aluminium rigger.The Leopard 4082 2000kv can be a good option for this project on 6S
                      but you wiil need to rebuild to whole package as others said the motor must compensate batteries so it will need to be located on the back of your boat.Gill
                      GO FAST AND TURN RIGHT !
                      www.grsboats.com.br
                      • urbs00007
                        • 857
                        rigger
                        yes, i built it over 20 years ago. would 3/16 " cable work ? any prop suggestions? with that leopard 4082 any speed predictions? it ran 83 with picco 45 stock. oval trim . cut down 1967 octura.
                        • urbs00007
                          • 857
                          rigger
                          would the swordfish 200 be a good choice?
                          • RaceMechaniX
                            • 3024
                            Wow,
                            I have not seen one of those aluminum riggers in 20 years as well. I recall a company Alumaweld making them.
                            The power system will just depend on what you can squeeze in there 33" is not much to work with.
                            TG
                            Tyler Garrard
                            NAMBA 639/IMPBA 20525
                            T-Hydro @ 142.94mph former WR
                            • urbs00007
                              • 857
                              fusion welding was my company. I built maybe a dozen (too labor intensive ) .90 version held x and f hydro straight-line records in I think 1992 . can fit swordfish 200 and 6- s 5,000 ma pack in motor compartment. should work out .
