Ricco 31" FE
  • HOTWATER
    • 2419
    Originally posted by sampit View Post
    I remove the spin Fin to replace with a pair of turn fins
    Do you think that would be better,or not necessary?
    Or Just adjust the one spin fin to 90 the one that I already have in the first post if iam using it for oval racing do i only need the one?
    I use two fins (helps it behave in the straights)....the right side fin is a little bigger than the left. With the boat sitting on a flat table and sitting level, set the right side fin so it just touches the table...the left side fin should sit a bit higher, maybe 1/2"....also the fins should be straight up and down, not kicked back much...
    I would use the one you have for the right side and maybe one of the smaller carbon fiber fins from OSE for the left...
    "Will race for cookies!"
    IMPBA D12
    My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
    • sampit
      • Jul 2009
      • 466
      I changed my mock up motor to a inrunner 4074 1400kv and got the COG right on at 10.5"
      the outrunner motor on the the inrunner mount didn't work right,
      I will follow the above trim setup thanks
      just need to get a good servo
      Do you run your flex with a liner? looking for the best way to fit the stuffing tube and keep it dry.
      FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
      Popeye Hydro T600 1400kv 6s1p
      • HOTWATER
        • 2419
        Sounds good. The servo I am using is a Futaba S3016....plenty strong enough...
        The carbon fin I am using for the left side of my Rico is part# 80049 ( you can also get part # 80062) both from the OSE store here ... http://www.offshoreelectrics.com/products.php?cat=67
        I am not using a teflon liner....1/4" stuffing tube with .187 cable...I get no water through this...
        Btw...I also run a seperate LiFE rec. pack...highly recommended! What esc do you have?
        IMPBA D12
        • HOTWATER
          • 2419
          Look here if you still need motor mounts... ---> http://southriverrcboats.com/shop/ca...aram=cid%3D%26
          IMPBA D12
          • sampit
            • Jul 2009
            • 466
            Using a Fighter Cat 8s 240Amp esc with the internal BEC
            bought the etti motor mount looks like it will ok
            • HOTWATER
              • 2419
              Sounds good...lmk if you need any more help with anything..AND please lmk how your maiden run goes....
              -Kent
              IMPBA D12
              • sampit
                • Jul 2009
                • 466
                -Kent
                Thanks for your help Kent, top man.
                will keep you updated and shoot a video off the madern, new motor on order, its a special TP but more about this when it arrives.
                • sampit
                  • Jul 2009
                  • 466
                  The result
                  TP 40mm x 82mm /4050
                  1450kv Dinogy 6s 5100. 65c
                  X646
                  All looking good so far , just a few more things to do
                  what's the best position guys for the turn fins?
                  then it ready for it maiden.
                  Just hope I don't have to run 2x3s packs instead of the 6s1p
                  COGs at 10.5" so hopefully it will ok
                  • Rumdog
                    • 6667
                    looks good. Let us know how she handles. I run the same hardware. Ended up cutting the stinger down to get the leading edge of the rudder in line with the leading edge of the prop. Helped handling quite a bit.
                    • HOTWATER
                      • 2419
                      I agree with Rum....I also extended my rudder bracket out about another 1 1/4"....
                      I also run 4S2P.....but run what you got.....
                      Sweet....I'm excited for you!
                      -Kent
                      IMPBA D12
                      • sampit
                        • Jul 2009
                        • 466
                        What do you think would be my best option
                        Extend the rudder some how! or replace the rudder with a longer arm one,or cut the stinger down
                        Do you think the rudder could be cut down in its length also as it does look very long for a FE
                        • Doug Smock
                          • 5359
                          I would extend the rudder back before I cut the stinger down on this boat. You need a piece of flat stock 1/8" X 1" x 3" . Take it all the way back to the transom.
                          You need approx 1" of rudder deeper than the prop at it's lowest point.
                          Where is your CG?
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • sampit
                            • Jul 2009
                            • 466
                            Thanks Doug
                            I have the cog at the moment is at 10.5" from the transom
                            I think that works out at around 30%
                            Does that sound about right?
                            • sampit
                              • Jul 2009
                              • 466
                              can anyone estimate a speed if if all goes well with this setup
                              Hoping to break 60 do you think that's possible.
                              • Doug Smock
                                • 5359
                                IME with the boat you are approx 1" forward with the CG. 30% is approx 9.5"
                                I see that Kent runs 34% in race water and that may work for you.
                                I like to keep the CG at 30% and add weight to the CG if the conditions are rough. Moving the CG forward can cause the boat to stuff if (when) it gets out of shape. You want it to fly level so it has a chance of recovering.
                                These boats tend to want to run a bit wet IMO compared to other monos the same size. Be careful and check temps often until you see what you have.
                                It's hard to tell by the pics but it looks like you may have more wire in your set up than you need. If that's the case shorten the leads, your equipment will thank you for it.
                                Just my .02
                                Good luck with it, I've had lots of fun with mine.
                                D.
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
