space between the shaft and the stingers
  • silver
    • 84
    I'm wondering if it is good to have a 4mm space between the shaft and the singers, my flexible shaft has a lengt of 250mm.
    it is said that you have to have the diameter of the flex shaft 1/4 as a space.
    I hope this is not too much so there will be too much friction on the engine bearings.
    some good advice from you guys would be cool.
    thanks
  • kevinpratt823
    • Aug 2012
    • 1462
    You'd be better off posting this in the questions and answers forum.
    It does look like a bit much(to me), but I don't see how that would put any more load on the motor bearings. I use thrust bearings between the coupler and motor as much as possible anyway, that takes a lot of load off the motor bearings if set up right.
    My private off road rc track
    • Basstronics
      • 2384
      You need a gap equal to the flex cable diameter, or close to as it contracts under load.
      So if you have done that you are good.
