Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Carbon parts - RcBoaters Forum
Carbon parts
  • shrive81
    • May 2012
    • 64
    Carbon parts
    Ok so I am in the middle of building a FC fantasm 41" cat and have been looking at other people's builds and noticed people are all making custom carbon fiber braces and what not... Where are u guys buying carbon sheets from and is it hard to cut yourself?
  • iamandrew
    • 576
    I buy mine from hobbyking,
    you can get it in sheets that are like 1.5, 2. 2.5 mm sheets
    you can cut it with a Jigsaw with a fine blade. but ive found easier to just use a thin hobby saw.
    Rememeber to wear gloves and a dust mask, carbon dust is BAD
    • shrive81
      • May 2012
      • 64
      O great thanks i didn't know they carries it
      • shrive81
        • May 2012
        • 64
        Looks like they only have it in the global warehouse I'm in the us does it take a longtime to get to the us?
        • dannybj26
          Going fast on the 836
          • Sep 2011
          • 333
          It would take about 3 weeks to get depending on the shipping that you choose
          -Danny
          losi scte full carbon,Hpi baja 5te,Hb tcxx
          Enforcer gator full mod 30cc
          Rico 31
          • kevinpratt823
            • Aug 2012
            • 1462
            halfway down the page
            My private off road rc track
            • shrive81
              • May 2012
              • 64
              Awesome thank you
              • kacordy
                • Oct 2012
                • 484
                CF
                Originally posted by shrive81 View Post
                Awesome thank you
                Dragonplate.com
                I made all my templates on paper, spray adhesived to the CF, then cut with dremal cut off wheel, sanded smooth, peeled off paper.
                • larryrose11
                  • Jun 2010
                  • 768
                  Dont use a saw when cutting CF.
                  Bad idea. The fiber catches, and can de-laminate it. Use a abrasive cut off wheel. If you have to use a saw, use something with just carbide crystals and no teeth.
                  • egneg
                    • 4759
                    I have used my dremel 4" table saw with a carbide blade and get very smooth cuts. Be prepared as the dust is worse than FG on your skin.
                    IMPBA 20481S D-12
                    • siberianhusky
                      • Dec 2009
                      • 2206
                      Clamped a jigsaw under a 1/4" plywood base and used one of these.
                      Can't saw I've done carbon plate but I've cut lots of fiberglass plate. Makes nice smooth cuts. Still have the original blade.
                      By clamping a straight edge to the base you can use it as a fence to make long straight cuts.
                      • mtbenjamin77
                        • 885
                        +1 siberianhusky
                        I draw my patterns on CAD the cover the CF plate in blue painters tape and spray glue the patterns to the tape. Keeps the CF from being damaged while cutting and the tape pulls off real easy. Then I use one of those diamond abrasive jigsaw blades and clamp my jigsaw upside down in my vise. It makes it very easy to see the patterns.
                        • kacordy
                          • Oct 2012
                          • 484
                          Clarify
                          Originally posted by kacordy View Post
                          Dragonplate.com
                          I will clarify. I use a dremal tool. But I use the very thin, brown stone wheel that is about 1.25 inches in diameter for all my straight cuts. It comes out perfect. Please use a respirator because of the powder dust it generates. I use a fine stone to sand all curves and corners.
                          • kingwrench
                            • Sep 2011
                            • 221
                            I make my own carbon sheets and parts, cut them out on my cnc router or by hand using a small scroll saw.
                            Top Gun 2011, "current problem" 88MPH. Top Gun 2014 "Marine One" 99 MPH. bet speed to date 125 MPH
                            • iamandrew
                              • 576
                              I like to grind my own beans
