jae 21 6s
  • sampit
    • Jul 2009
    • 447
    jae 21 6s
    Does any know what the max size 6s liop that can fit in the jae?
    thinking about building one to run a TP3674 1700kv motor, just not sure what the best fitting 6s pack would be.
    would a 5100 6s DINOGY fit. or is a 4s setup a better option.
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
  • martin
    • 2869
    Sam i know a Turnigy Nano 6s 45c - 90c does fit ok, their 49 x 50 x 157. I only have the size of a Dinogy 6s 5000mah which is 57 x 46 x 160, the dimensions of the JAE 21fe tub is (inside sizes) 63mm wide x 54mm high. The hatch width opening is 46mm. Hope this may help. Martin.
    • martin
      • 2869
      By the way to get the Turnigy 6 cell in you need to cut away the lip that the hatch sits on, its tight but it just goes in. Looking at the size of the Dinogy i dont think youll get them in as their quite a bit bigger.
      • sampit
        • Jul 2009
        • 447
        Thanks Martin, looks likes the jae idea is out the window
        Do anyone know what other hull I could run a single 6s 5100 pack in cat, mono.or hydro
