Motor shaft length - To cut or not to cut
  • gyrotron
    • 499
    Hello Guys,
    I would like to know if it is a common practice to cut the motor shaft. My initial thought is that the length comes from factory therefore if I cut it the motor's warranty will be void. If the manufacturer designed the shaft to a certain length, then it should be left as is. On the other hand if cutting motor shafts is a common practice then what max length should it be? What is the criteria for selecting "a" or "b" length?
    Thank you!
    I have cut a few of mine where needed.When I have I cut where a thrust bearing and the collet installed leaves too much gap for the spacer(or none) which is handy.Mind you I have only had to do this for my twins which can be tight for flex alignment.
    So what motor/application are we speaking?
    • stadiumyamaha
      • 1371
      You may need to cut the shaft in order do a direct replacement of many rtr motors.
      I've needed to on geicos when using a leopard motor because there isn't enough clearance between the collet and the stuffing tube even with the motor mount in the farthest back position.
      • Doug Smock
        • 5359
        If you decide to cut the motor shaft make certain that you take precautions (tape etc.) to keep the metal debris out of the motor.
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • gyrotron
          • 499
          Guys,
          Please take a look at the final layout before rails get glued. To me I don't see any harm on leaving the motor shaft unmodified to stock length but at this point I am looking at it still with untrained eyes. Will it be ok to leave it like it is now?
          Thank you
          • BHChieftain
            Fast Electric Addict
            • 2051
            I have had to cut shafts on about half of my setups, just to get stuff to fit. They actually cut easity with a cutting wheel on a dremmel tool, like it was said you should put the motor in a plastic baggie and tape it up well as debris will ruin the motor as it sticks to the magnets. Then use a grinding bit to make a new flat spot (less is more...).
            On your setup, I'd just try it without cutting-- if you are not seeing any vibrations then you should be fine.
            If you wanted to use a thrust bearing on your motor you would have to cut it back.
            Chief
            • Doug Smock
              • 5359
              Originally posted by gyrotron View Post
              Guys,
              Thank you
              Personally I'd cut it back a bit just to make it look better.
              You could certainly leave it as Chief said.
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • gyrotron
                • 499
                If you were to cut it how much would you cut?
                • Doug Smock
                  • 5359
                  It's hard to tell looking at the pic. I'd cut it back just far enough that the motor mounting screws won't interfere with you getting a wrench on the collet.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • gyrotron
                    • 499
                    Ok, I got the reference for cutting I needed. I will be runing it first with the motor shaft's length the way it's shown on the picture. I'll keep an eye/ear for out of the ordinary vibrations when the maiden run comes along. Thank you.
