Want more speed - top end
  • rhgraphix
    • Nov 2012
    • 47
    I have a 32" pursuit and currently running the stock 1620 motor. I am using 2 50C 7.4V 2s batteries. I have a seaking 120A speed controller.
    What I was wondering to get more top end what motor I could step up to running the same batteries and speed controller. Just a simple motor swap.
    What are you guys thoughts??? Help I'm a newbie for sure. Thanks!!!
  • dana
    • Mar 2010
    • 3660
    Leopard 3674 2200kv
    • stadiumyamaha
      • 1371
      +1 Dana
      I'm running a cc1515 2200kv in mine. Rips!ImageUploadedByTapatalk1355426129.573779.jpg
      • jkr
        FE Addiction
        • 582
        Originally posted by dana View Post
        Leopard 3674 2200kv
        With Octura 640-642 or Prather s215-s220 prop.
        • dana
          • Mar 2010
          • 3660
          I was gonna suggest x442. Start with a little less pitch than x6 or prather 1.5
            The weak point is the controller. It takes more watts to go faster, and since volts are the same that means more amps are needed. There is no free lunch, eventually the ESC will pop. I recommend starting low as Dana recommends and stepping up on small change in prop load at a time. Or buy a T-180 and go fst enough to blow the boat off the water.
            • jkr
              FE Addiction
              • 582
              I was running a detonque 642 with t120 and leo 3674 2200kv with no problems.
              Also all my connectors were 6mm.
              • rhgraphix
                • Nov 2012
                • 47
                That all sounds great. I have a octura x440 coming in the mail. Also I looked at that t180. I think I will start with the motor and then upgrade the controller.
                Thanks again everyone. I will let you know how it goes!!!
