Still too hot !!
  • bigmmmike
    • Oct 2011
    • 19
    Still too hot !!
    Got a new Tacon Brushless Motor LBP4074/2.5Y-2000KV & New Turnigy Marine 180A ESC still running hot Prop wrong ?
  • MAMBA2200
    I need a scooby snack
    • 1196
    what prop what boat what voltage i run the same thing mine is the 2150kv mine runs cool all the time
    • dana
      • Mar 2010
      • 3570
      What boat? What prop? What timing? What batteries?
      • MAMBA2200
        • 1196
        good call dana lol
        • dana
          • Mar 2010
          • 3570
          Oh and what is "hot"? 140 degrees?
            • 4297
            Pictures of the setup,
            And video of boat running in a straight line would be good to.
              • 7990
              In July the OP's problem was - apparently - a shorted ESC in his Apparition which caused things to get hot by the time he finished taping up. Is this still the problem, or is the boat running now and thermals off?
              • bigmmmike
                • Oct 2011
                • 19
                Yes Fluid ESC heats up while Taping to the point of no go when its tossed into my Lake
                • dana
                  • Mar 2010
                  • 3570
                  Why would you not replace the esc?
                  • bigmmmike
                    • Oct 2011
                    • 19
                    I did ... got a new one doing the same thing so hot smells and cannot touch
                    • dana
                      • Mar 2010
                      • 3570
                      My bad you did say its new. So something must be plugged on backwards?
                        • 4297
                        Like I said pictures,
                        Of setup and what part of the esc is getting hot.
                        And how hot with temp probe.
                        • madmikepags
                          • Aug 2012
                          • 1359
                          you using a reciever pack or bec? if the esc has a bec and you're using a rec pack without unplugging the red wire on the esc this will heat the controller up. also make sure the neutral position is set correctly.
                          We call ourselves the "Q"
