revolt 30 vs impulse31
  • superslick
    • Dec 2012
    • 34
    OK guys. What the deal with the impulse 31 . I have been hearing allot of different things about both revolt and impulse. I see there somewhat competing against each other. What's the deal which is better. I saw video today a revolt flying by an impulse. So I'm stuck between a revolt or impulse. Tomorrow I order my boat ugh
  • MAMBA2200
    I need a scooby snack
    • 1347
    Both good boats but any rtr will have issues to deal with and it depends what electronics you put in them as far as speed goes i have a revolt and was looking at both when i got mine but the hardware on the revolt is why i went with it it just looked better to me
    Sent from my DROID RAZR using Tapatalk 2
    • superslick
      • Dec 2012
      • 34
      What's your setup for the revolt
      • MAMBA2200
        • 1347
        Tacon 4074 2150kv seaking 180a m545 prop there a video in the video forum of a run i did yesterday
        • superslick
          • Dec 2012
          • 34
          Haha I had the same tacon On my tunnel hull. The power that was coming off it I had to add 2nd dagger board in the center...I kinda like the metal on revolt. This will proberly be my 6th boat.
            • 7512
            Having owned both...the Revolt would be my preferance.
            • superslick
              • Dec 2012
              • 34
              Ok I ended up getting a revolt 30 and Ul-1 hydro this morning at 8:30am . I am very impressed with it both. Took both for soin this morning and worked out great did some minor trim adjustments. Any prop recomendations for the UL-1?
              My 5yr old son loves the Ul-1. He also says hope to join ose and find people to race in the area.
              • MAMBA2200
                • 1347
                the kids are the OSE future gotta love those father son rc adventures
                • superslick
                  • Dec 2012
                  • 34
                  Yuppp...there always those days where the Word "slow down" Means go faster. Have you ever owned ul-1
                  • G-UNIT
                    • 971
                    Go with a octura m445 on the ul-1 its a great prop for that boat, be sure to sharpen and balance it.
                    the m445 should get you close to if not more then 50mph.
                    • kevinpratt823
                      • Aug 2012
                      • 1462
                      Plenty of prop info in the UL-1 forum. Personally I didn't like the m445 because of the handling, Grim 40/57-3 wih some work on it and I run about 50 with good handling. I have an Impulse(older version), but if I did it again I may have gone Revolt.........
                      My private off road rc track
                      • dana
                        • Mar 2010
                        • 3660
                        I gotta agree with Kevin. M445 just made it handle terrible
                        • mannytx1
                          Fast Electric Adict!
                          • Oct 2012
                          • 99
                          The hull revolt30 and impulse31 (29 ") are almost equal, the revolt is not separated from the water, is more stable
                          I try revolt30, with electronics impulse31 v2 (5s and 6s) and it's amazing
                          Revolt30
                          Hi, Mike grimracer zaborowski
                          I think there are serious problems with the design of the rudder, the water pickup hole is very high, need 1 inch below ( the water pickup hole should be no less than one inch below the keel) very small rudder, a minimum recommended length is 1 times the diameter of its support below Lx 15% 30”x15% = 4,5” minimum. (REVOLT 30 ONLY 4")
                          thank you very much
                          Manny
                          • BHChieftain
                            Fast Electric Addict
                            • 2051
                            thank you very much
                            Manny
                            Manny, I've seen you post this exact same post across about 4 or 5 threads with anything that mentions "Revolt". First of all, your formula and comments don't make any sense, secondly, I've not seen anyone claim they have a cooling problem, third, the AQ Marine ESC has been around for years and is one of the more common ESCs in the industry.
                            Please stop trolling and contribute something useful.
                            Chief
                              • 7512
                              [ATTACH=CONFIG]99456[/ATTACH][ATTACH=CONFIG]99457[/ATTACH]
                              Revolt30
                              thank you very much
                              Manny
                              Another one! Good God man...ny show us where you came up with this instead of posting it all over the net!
