Cold Water Running?
  • St3alth_Frenzy
    • Oct 2012
    • 55
    Cold Water Running?
    So I am 80% sure that i will be getting myself a AQ revolt for Christmas this year, and I dont want to wait until spring to run it. So I know a spot that is open water all year long, and I know that the water temp there has gone below 0. Could the super cold water cause problems with the boat? And if there would be problems, how could I solve them?
  • Chilli
    • 3067
    There shouldn't be any problems operating in cold water/weather other than slugish performanc out of your batteries. The power may pic up as you run the boat and the packs heat up. You can prewarm the packs if you want but it's probably not necessary.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • MAMBA2200
      I need a scooby snack
      • 1196
      just do what chilli says and make sure your packs are warm and you will be kool i run my boats all winter even when theres snow never had a problem yet
      • BHChieftain
        Fast Electric Addict
        • 1964
        A bit off topic, but I recently saw a video of someone running a miss Geico cat *in* the snow-- go look in the "videos" section here on the forums.
        (worked surprising well)
        8^)
        Chief
        • St3alth_Frenzy
          • Oct 2012
          • 55
          I was mainly worried about the cooling lines/plates freezing, and cracking/rupturing because of it. But now that I think about it, as long as I don't let the water sit in the lines, they should be fine.
          I know lipo's preform better warm. (keeping them in your pocket works well)
          And that vid of the boat running in the snow I have seen before. With the amount of powder that we get up here, I might be able to do it also.
          • Southwest
            • 274
            Remember that the waterlines will pickup heat as they go thru the esc and motor which will ease your worry. Best route would be to decrease your runtime some and like the guys say, warm up your lipos to a good room temp and go have a great time!!! Running in the snow will increase amp draw and will keep lipos warm.
