Stainless stuffing tube
  • brg65
    • Nov 2012
    • 15
    im wondering if anyone has used the 1/4 inch stainless tubing for a stuffing tube. or is it best to just stick with the brass stuff. The .187 flex seems to fit a bit more snug in the stainless.
  • Rumdog
    • 6667
    Just use brass. easier to work with
    • Jason4636
      • 712
      You can use SS if you want, but on that small of a flex. Brass is just easier to bend. I know when I build my boat this winter, I'm going to run SS for added protection if one of my flex shafts come apart. But my 2 runs will only be 3-4" long and run a 1/4" flex.
      • brg65
        • Nov 2012
        • 15
        Ok im sticking with the brass tubing. Im getting all the parts ordered for a fightercat fantasm build. Doing a single. Is the 12 inch 1/4 tube long enough ? The hull isnt in yet, but i have the OSE 80085 strut and rudder system, this sound good ? Also will be running a Leopard 4092 1480 kv on 6s. Castel 240 ice esc. Any input or ideas from members would be helpfull. Prop size ? COG ?
        • Jason4636
          • 712
          I have a single Fantasm and I just measured my stuffing tube. It's only 8" long, so you should be good with the 12" .
          That strut would be fine, but I hate inline rudders. This is whats is on mine, and its only $36
          I like HV setups myself. I have a TP 4092 980kv run on8, 9 an 10s. The fastest I've had my boat is 69.2mph running on 9s with a x455. I'm waiting to put my Miss Geico back together for a recovery boat. Then I'm going to try out my S235 on 9s and 10s
          • brg65
            • Nov 2012
            • 15
            Thanx for the info Jason. Id be interested in seeing your Fantasm, do you have pix ?
            • Jason4636
              • 712
              Here's a link to it. I'd have posted pic's. But on my way out the door for work.
              http://keithbradleyboats.freeforums....tasm-t177.html
