Ok guys i need help in a bad way i have 2 boats that are giving issues.I am running seaking speed controls in both boats one is a 120 and the other is a 180. When i first put them in the water and go to take off they blast out of the water and then seem to just go into safe mode. That is the best way i can describe it the seem to have full power for a split second and then only 3/4 power. I am using 2150 kv motors d wind and on my mystic i have blown 2 castle bec's in 2 runs. I have tried lowering timing making adjustments on my controler props and all i dont know what else to do please help.
Electronics Problem?????????
turn the lvc off and time your run. I've dont the same with the T-180Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
I just calibrate throttle and leave them on auto. Maybe a timing change but, thats it.
I have done the timing change guess i will try the lvc and use a lvc alarm and do a short run and see what happens i guess what timing is best on a d wind motor???
Sent from my DROID RAZR using Tapatalk 2Im Only Responsible For What I Say Not For What You Understand
I would start with 3.75 and go from thereModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
thanks jason on the timingainside.jpgIm Only Responsible For What I Say Not For What You Understand
