Eagle Tree USB Micro Power E-Logger
  • Darin Jordan
    • 8332
    Originally posted by Battlepack View Post
    Someone told be yeaterday that they are coming with a 40" N2 that is pulling 1000 watts and it's going to leave a huge wake and take all of you small boat guys out the first lap.
    Bring it on! :D
    Darin E. Jordan - Renton, WA
    • sjslhill
      • 1514
      With the new 250amp controllers, it's possible. I figure your being quite about it and doing it yourself. : - )
      I figure you can run 3000 watts in P hydro.
      • SJFE
        • 4735
        And power a small town.....LOL
        • Darin Jordan
          • 8332
          Steve,
          Just a quick question... are the Loggers you sell the version with the Deans pre-installed, or with the wire?? I can make either work... just curious...
          Thanks,
          • admin
            Administrator
            • Mar 2007
            • 49
            I "THINK" (gets me in trouble!) that they only make the micro with deans installed.
            Looks like this.
            • Darin Jordan
              • 8332
              Nope... From the Eagletree Systems website:
              Part #: MPR-LEADS
              ( http://www.eagletreesystems.com/MicroPower/4.htm )
              No big deal... like I said, I can make it work either way... have plenty of Deans laying around and am getting really good and configuring adapters to fit my 6mm contacts...
              • Darin Jordan
                • 8332
                Steven,
                I just wanted to confirm with you... When the additional accessory leads for the V2 become available (memory expander, airspeed, multi-expander specifically), are you planning on carrying them? I'd like to get them, but they are pre-order only right now, and if I have to wait, I'd rather wait and get them from you...
                Also, are you planning on carrying the loop-temp sensor?
                I got my V2 all set up last night and ready to install... haven't even used it yet and I'm already "Jonesin" to increase it's capabilities!
                By the way... what have others solutions been to installing the Brushless RPM sensor? In the future... I'll add a tap to the motor leads (at least two of them) using a short piece of wire and a 3.5mm connector, but for now, I just installed a male 3.5mm connector on the lead from the sensor, and them soldered a sewing pin into the wire side of a female 3.5mm connector (did this to both "Motor 1" and "Motor 2" leads)... I'll just stick it into the motor wire... Easy to install and remove...
                • SJFE
                  • 4735
                  Can that unit run dual temp probes? I only see one set of pins.
                  • Darin Jordan
                    • 8332
                    Yes, but you have to choose not to run the RPM probe...
                    Once the expander is available, you'll be able to run a pair of temp probes AND the RPM... which is ideal for FE... Battery and Motor temps are what I'm after concerning temps...
                    • ED66677
                      • 1300
                      Just received mine today :D
                      The software is amazing!
                      Emmanuel
                      • NorthernBoater
                        • 811
                        The software does run on Windows 98SE.
                        • ED66677
                          • 1300
                          The manual says 98SE, Millenium, 2K and XP
                          Emmanuel
