Flex wire lubrication in teflon tube?
  • flyboy320
    • Mar 2008
    • 95
    I use oil with my flex cable that doesn't use a teflon liner, and now with a new boat build, I have used a teflon liner, and I'm wondering what I should use for lubrication?
    Is oil OK, or will this corrode or eat away at the teflon over time?
  • G Doggett
    • 477
    Just use the same oil, or grease, nothing will eat teflon.
    The teflon could probably be run dry, but the idea is that the oil will work its way down to keep lubing the stub shaft.
    Graham.
    • flyboy320
      • Mar 2008
      • 95
      Thanks bud :)
      • z400
        • 1333
        Why did you switch to the teflon tube?
        Z
        KBB34" Mono - Fast
        ToySport Triton- Not as fast
        • flyboy320
          • Mar 2008
          • 95
          Well the first boat I bought didn't have one, so I ran it the way it was (flex cable in a brass stuffing tube). When I did my first boat build, it was recommended by the builder to use a Teflon tube drive system. Being a newbie with boats, I followed his advice :)
          • z400
            • 1333
            Oh gotcha
            well good job for following their advice!
            I just recently just had to go from running a teflon tube
            to not running a teflon tube only because i dont know
            what size brass stuffing tube is on this boat i have, and i dont
            have much time i guess to try out a .187 in it
            Z
            KBB34" Mono - Fast
