Esc recomendation
  • GatorsFan
    • Aug 2012
    • 34
    Esc recomendation
    Was wondering what esc's would be recomended for a dual motor setup with 1800kv motors in a 36" catamaran
  • SpeedFreak_86
    • 203
    a set of speaking 180's and a program card would be a great step in the right direction. I've got three now, one in everyone of my fe boats. There reliable and water proof, had one of the under three times now...
    Slow and steady isn't my pace
    • GatorsFan
      • Aug 2012
      • 34
      Ok thanks i was hoping i could use the 120's just cuz of price but i guess ill look into the 180's
      • dana
        • Mar 2010
        • 3660
        What motors? Can size? Props?
        • GatorsFan
          • Aug 2012
          • 34
          to be honest i got the motors off ebay not sure what the can size is all i know is they are 1800kv. how would i figure out what size the cans are? props are octura x442
          • dana
            • Mar 2010
            • 3660
            Measure them
            • dana
              • Mar 2010
              • 3660
              Is there a brand name?
              • dana
                • Mar 2010
                • 3660
                Also what packs are you running?
                  Take some pictures of them if you can and post them,
                  They may be the cheap 2 pole motors that come in the HK boats.
                  And they run hot some times and eat the amps up to.
                  • GatorsFan
                    • Aug 2012
                    • 34
                    36mm diameter 57 mm long was looking to run 4oc 5000mah 4s gens ace packs no name on the motors cant remember what brand they are
                    • dana
                      • Mar 2010
                      • 3660
                      The 120 should be fine. 180 is always great to have more headroom, but not nessecary in your case
                      • GatorsFan
                        • Aug 2012
                        • 34
                        ok thanks this is what i found on the motor XYH-B3656 KV1800 Brushless Inrunner Motor For 1/8 Scale RC cars And RC Boats i may look into the 180's just to be safe
                          Ok,
                          This is the motors that you bought ? http://www.ebay.com/itm/XYH-B3656-KV...p2047675.l2557
                          If so there good to 5s but I would say with 4s and check temps at 1 minute and then 3 minutes.
                          • GatorsFan
                            • Aug 2012
                            • 34
                            yes those are the motors one other question will the seaking esc's work with a pistol grip tx
                            • GatorsFan
                              • Aug 2012
                              • 34
                              sorry for all the question im alittle new to this what is a good temp range to be in
