Lipo Help!
  • WiKD1
    • 3
    Lipo Help!
    I have two hextronik D9 3s 1700ma packs. One pack reads between 4.1-4.23 between each cell (measured on the balance plug). The problem is it only will only read 4.23 volts on the main dicharge plug insted of the 11+ volts it should. Why is that? Both packs now only read around 4 volts on the discharge plug. Did I kill them?
    Thanks in advance and great site!!
  • NorthernBoater
    • 869
    Are you measuring at the balance leads or the battery leads?
    • WiKD1
      • 3
      I think i found the problem. I was measuring each cell wrong on the bal con. I was using the black for the ground on all the cells and not measuring them across each cell. I remeasured the correct way and got 4.23 on one cell and .02 on the others. Is it dead????
      • WiKD1
        • 3
        Does hextroniks have a warranty? The packs are 2 weeks old and have less then 5 charges on them. I purchased them from hobbycity.com (unitedhobbies) with a ic6 charger and lipo ESC and brushless.
        Thanks
        • NorthernBoater
          • 869
          Here is their policy on LiPos.
            Was the pack fully charged when you are measured it? What happened when you put the balancer on the pack? Did you use a low voltage cutoff when running the pack? Did the pack ever get wet? What was the boat/motor/prop combo?
            If the total pack voltage is under 12.6 volts fully charged then either two cells are damaged, or there is an internal short/bypass. Looking at the UH waranty, it appears that you are probably SOL. Sorry.
