What clear coat to use?
  • kphilliprc
    • Sep 2011
    • 28
    Can anyone tell me what clear coat would be best for use on a Venom Segad's factory paint? I had to do some work on it and want to make sure I get what's best to clear over it. I had to repaint a small area but need to clear that and part of the original finish to blend the clear coats back together. I'm thinking it will be best to wet sand the whole boat and clear the whole thing for the best results. Is the Segad gelcoated? If so, as long and it's sanded down with 800 grit, will paint like an automotive clear or Krylon clear do the job?
    Any help would be appreciated.
    Keith
  • siberianhusky
    • Dec 2009
    • 2206
    If you have the equipment go with 2 part automotive clear, much, much tougher than any of the single part or spray can clears. Can also be buffed to a beautiful deep shine.
    • egneg
      • 4759
      I would contact the manufacturer because the wrong paint will cause the original paint to lift and you will have a big mess.
      IMPBA 20481S D-12
      • carlcisneros
        • Jan 2010
        • 1237
        BUT, I have used this paint over just about everything under the sun and I have
        not had a problem as YET. http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
        • siberianhusky
          • Dec 2009
          • 2206
          SAme here I'd do a test spot but I've sprayed the 2 part stuff over many kinds of paint with no issues, even some kind of water based acrylic art paint on a guitar with no issues.
          • egneg
            • 4759
            At least do a couple of barrier coats first.
            IMPBA 20481S D-12
            • CircusCircus
              • Jan 2009
              • 325
              I would reccomend automotive paint, much more durable than krylon or any rattle can clear for that matter. You can spray autmotive clear on just about anything without issues, just not oil and grease. Ive sprayed it over enamel, laquer, gelcoat, watebase, plastic etc. As long as the surface is prepped properly and clean it will stick.
              I would not try and spot repair with it though, you will get a much nicer cleaner job just scuffing the entire boat with a scotch brite, and clearing the entire boat again.
              R/C Unlimiteds
              NAMBA 237
              • CircusCircus
                • Jan 2009
                • 325
                Also something to consider is bring the boat to a reputable body shop and let them clear it for you, that way you dont have to spend alot of money on materials and arent stuck with leftovers.
                R/C Unlimiteds
                NAMBA 237
                  Just my 2 cents here,but I use U-Pol Clear#1.It comes in a rattle can and comes out with a nice thick clear.Do test a piece first though as It has done things to some of my model paints.
                  • tiqueman
                    • Jul 2009
                    • 5866
                    I second that UPOL all the way. can be used over several different types of paints
                    • kphilliprc
                      • Sep 2011
                      • 28
                      That's what I'm going to do. I've got the whole boat wet sanded with 800 grit and am ready for clear coat.
                      Thanks, for the advice.
                      • kphilliprc
                        • Sep 2011
                        • 28
                        Thanks everyone for your ideas!!
                        • kphilliprc
                          • Sep 2011
                          • 28
                          So I just went to Advanced Auto to look at their automotive clear. I was going to get it but then I remembered a friend of mine told me that I should be careful about laquer clear coat cause he had experience with it lifting the paint. Is this the kind of paint you are saying you've had good luck with? The one with laquer in it?
                          • kphilliprc
                            • Sep 2011
                            • 28
                            Just found a local auto paint store that had some UPOL in stock and picked up a can.
                            Thanks again guys.
                            • tiqueman
                              • Jul 2009
                              • 5866
                              I personally would get real auto clear... not duplicolor etc from auto parts stores. If you can go to a real automotive paint shop or search online for upol clear in a can. A little more money for a non comparable difference. Ppg, omni, hok, etc etc will also be much better choices. The duplicolors etc just don't shine like they should and i wouldn't buy them again if they were $1.00......
