Mould making resin question
  • siberianhusky
    • Dec 2009
    • 2206
    I plan to do the canopy layup in epoxy resin but is it OK to use polyester resin for making a one off mould?
    Much cheaper than West epoxy for something that will more than likely be used once.
    Next question do I have to use tooling resin or is gel coat good enough for one time use, is that even required? Can I just polish and wax then PVA the plain resin?
    Found plenty of info about making the plug and mould but not to much about the minimum requirements for a single use.
    Thanks
  • iamandrew
    • 576
    Sure is ok
    in fact, most, if not all moulds are usually polyester resin based.
    ... i dont like gelcoat...
    • phil t
      • Feb 2010
      • 195
      Dont need gel coat, brush on a coat of resin let it setup a bit till it gels then you can lay on cloth and more resin to make your mold. You can polish the resin if needed.
      Phil Thomas
      email supersport45@aol.com
      http://www.philthomashydros.com
      • siberianhusky
        • Dec 2009
        • 2206
        Thanks, straight poop from one of the masters!
        Cheers
