Mounting William Racing Motor Mount CC 2028 Help
  • Biscutz
    • 4
    Hello,
    I need a little advice on mounting a William Racing Aluminum Motor mount for my Cast 2028. I will be installing this in a 47" deep v. My concern is getting the aluminum mount to stay put with epoxy. I was thinking of reinforcing the hull as well while I am at it. I went ahead and drilled a bunch of holes along the base of the mount and I plan on scrapping the base up with 60 grit sandpaper. Is there anything else I should consider before I glass/epoxy this thing in? The 2028 is going to have a lot of torque, so I want to make sure the mount stays put.
    Thanks.
    Ian
  • siberianhusky
    • Dec 2009
    • 2206
    Give the hull a good scuffing and clean it all with degreaser, I've changed to JB weld for mounting motors, killer stuff. Mounted 4 or 5 now with it, no problems.
    • Biscutz
      • 4
      Is there a type of JB weld you have used or just the standard stuff at HD? Should I make sure it gets through all the holes I drilled on the bottom of the base?
      • longballlumber
        • 3417
        Which William’s mount is this? All of the mounts I've gotten from Jim us fasteners of some sort (i.e. through the bottom of the hull or onto a couple of rails in the hull).
        Later,
        Mike
        • Biscutz
          • 4
          Mike,
          This mount does have screw holes at the bottom, 4 to be exact an all four corners. I was planning on using epoxy to fasten the mount to the hull. I really didnt' want to use wood if I could help it but if it makes more sense I can do so.
          • longballlumber
            • 3417
            This is my personal opinion, but I ALWAYS avoid bonding in a motor mount. I would reenforce the bottom of the hull....
            Nevermind, I just noticed that you putting this in a mono hull (deep vee). I would much rather have a couple of nice wooden stringer in the hull and us a rail mount system rather than glueing in that huge chunk of nicely machined aluminum... Buy, hey, that's just me.
            Good Luck!
            Mike
            • KartRacer
              • Aug 2012
              • 363
              My very limited experience has suggested a problem with epoxy bonding to a reinforced, CF/Kevlar lined hull. Seems as if the additional items have a difficult time bonding to the hardened epoxy. Obviously everyone here has done this with limited or no problem, but I would like to come up with a better option. I am beginning to think that the rail system may be more reliable. I think I am going to attach all mounts prior to hull reinforcement on my next build. The as shipped hull has a rougher texture and I am wondering if the other items will be more secure this way.
              KartRacer ~ Dennis B
              Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
              • RandyatBBY
                • 3943
                All you need to do is scuff with sand paper the hull ware you want the epoxy to stick. A rail system will eliminate flex if it goes all the way to the transom in a mono.
                Randy
                BBY Racing
                • justski
                  • 254
                  the slow drying JB weld is stronger than the fast drying
