Painting my first hull.....HELP??
  • BlackSnakeRacing
    • 59
    Hey all have finally decided it is time to pretty up my osprey hull a little before summer hits. I have stripped all the old stickers off and wet sanded the hull with 800 wet and dry. Now do i have to prime it before i put a base coat on or can i start with the base coat/ airbrush the sanded fiberglass? I am planning on trying a bit of airbrushing on the hull, and i use waterbased paints to airbrush, so what kind of paint should i use for the basecoat/clear? I know the waterbased paint isnt the best to use but its what i have and need to keep the costs down.
    Thanks for the help
    Cars and planes are for fun... Boats are for serious racing Bust Out Another Thousand
  • kevinlew211
    • 706
    No need prime for gel coat boat, but 800 is still to thick, finished with 1500 or 2000 at least, I used to paint my boat with PPG to $.99 can from warlmart, not big different, your skill is more important, bigger boat is harder to paint.
    • BlackSnakeRacing
      • 59
      what about airbrushing on the gelcoat? will that work or will a base coat be needed?
      • dana
        • Mar 2010
        • 3660
        Gelcoat is its own primer. Done deal.
        Waterbased is ok, but you are better off to protect it with clearcoat. Urethane two part clear is the best
        • kevinlew211
          • 706
          Thats I dunno, let some airbrush guy chime in...
          • kevinlew211
            • 706
            Thanks Dana, you got all the answer you want I guess, good luck with painting your 1st boat
            • BlackSnakeRacing
              • 59
              Thanks Dana, i was planning on clearcoating it, dont want to put a heap of effort in for it to get damaged easily.
              Kevin thanks for your help as well, if it turns out any good i'll post some pics up
              • dana
                • Mar 2010
                • 3660
                Kevin, you're right on man.
                Black, no prob man
