Seaducer hulls
  • SpeedFreak_86
    • 203
    Seaducer hulls
    Any of you guys know anything about seaducer hulls?
    Slow and steady isn't my pace
  • Switch
    • 54
    Seen them run in "A mono" as a .21 nitro setup (crazy fast little buggers) and I was flat impressed that is a sweet hull. Id like to try one myself as an FE setup some day. Im not a real exspericed person in boats yet but seems like a great hull design and alot of guys run them with good reviews. I think that hull design hold several records even.
    • Chilli
      • 3204
      They can be hard to set up but when you get it right they run awesome. They are also tight on space in the inside and hard to tape up. That's why you don't see too many FE ones running. Doug Smock has taken a bunch of IMPBA straight away records with them. All that being said, I had a bad experience with Seaducer so I can't say I would recommend one.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • SpeedFreak_86
        • 203
        I just picked one up for a $100 it's 28" long 9" wide almost 3.5" tall
        • SpeedFreak_86
          • 203
          Yea I was looking at making it a fe boat but making a top for it might be difficult..... I'm thinking nitro might be the way to go on this one the guy included some type of tuned pipe with it as we'll. I'm excited about starting this build.
          • RaceMechaniX
            • 3024
            You've got the shorter of the two versions. Jerry makes a 33" and a 29". They are a bit tricky to set-up, but can be awesome when done right. I have a 21, 45 and 101 in nitro and a 33" version was my first FE. Mine ran very wet and I sold it prematurely without trying to fix it first. Some pics attached.
            Tyler
            Tyler Garrard
            NAMBA 639/IMPBA 20525
            T-Hydro @ 142.94mph former WR
            • crrcboatz
              • Jan 2009
              • 1103
              I have a 38" version with hardware but no cowl. Was going to use Lexan to make one for it. Interested let me know can send u pics and possibly sell
              • SpeedFreak_86
                • 203
                Ok kool, thanks ccr. How are they tricky to set up? When you say running wet is that where the front of the boat want to nose in the water?
                • SpeedFreak_86
                  • 203
                  Any suggestions on a descent hardware set up?
                  • RaceMechaniX
                    • 3024
                    Use the Seaducer hardware or Speedmaster. These boats are very particular with hardware so I would not recommend a stinger or longer offset rudder.
                    Tyler Garrard
                    • RaceMechaniX
                      • 3024
                      Originally posted by Mike Caruso
                      If you built one today which motor and esc would you like to use fun not race.
                      Probably a T180 and a leopard equivalent to a Neu 1521
                      Tyler Garrard
                      • SpeedFreak_86
                        • 203
                        Hey race, what strut is that?
                        • Doug Smock
                          • 5359
                          Hey Chris,
                          You want the 20 mono rudder and the SDS strut. http://www.seaducerboats.com/hardware.htm
                          The set up instructions are on the site.
                          Good luck.
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • RaceMechaniX
                            • 3024
                            Those are the supplied Seaducer hardware, 21 Strut and rudder.
                            TG
                            Tyler Garrard
                            • RaceMechaniX
                              • 3024
                              Doug,
                              Do you run the 29" or 33" hull?
                              Tyler
                              Originally posted by D.Smock View Post
                              Hey Chris,
                              Good luck.
                              Doug
                              [ATTACH=CONFIG]87686[/ATTACH]
                              Tyler Garrard
