Open Letter To SJFE
  • robby76
    • 207
    Open Letter To SJFE
    SJFE, thanks for all the reasearch & developement you have done.
    i bought two HM200 amp escs and encapsulated one like on your 26 inch cat. the other i left as is on my twin 42 inch 13 pound twin geared/drive cat.
    todays run on 18 mph winds and some chop still managed 41 mph on the X447 two bladers.
    what was interesting were the temps. nimh cells were 115' , water cooled fiegao motors were 100' , as is esc 114' and the encapsulated esc was 106' .
    the escs did not like the pistix adapter so removed it out.
    and with the 4mm "O" rings on the teflon tube between the gap of stinger was a perfect fix. this time noot a spec of water was inside the hull.
    again, thank you.
  • Mich. Maniac
    • 1456
    how long does it take to receive? did you water cool it?
    thanks
    mike
    • SJFE
      • 4867
      Robert
      You are more than welcome. Now more than ever we need to try and save money where we can...with minimal risks. This R&D has paid off well. Lets hope we can find more products like this.
      Tom G
      • robby76
        • 207
        thanks
        mike
        took 3 days fed ex. key is to buy at night close to midnight.
        make sure you test it before encapsulating it.
        did not install the tubes like SJFE did. next one i do, i will maybe soldered onto a flat piece of copper on bottom.
        i was pulling 66 amps so i unless you run close to 200 amps it might not need the extra heat sink.
        DP270 was great. it is alot like syrup.
        • SJFE
          • 4867
          Robert I agree with you on the tubes. In retrospect I would not do it again either. I will use plates and fans from now on. The DP270 is a great product!!!
