Heads-Up for Genesis owners
  • viper1
    • 219
    Heads-Up for Genesis owners who still use the original rudder;
    I noticed slightly higher motor temps in my last couple of runs.
    My rudder pick-up is used for motor + mount cooling only, and I have a dual pickup for the ESC.
    As I suspected rudder blockage with mud or something (very shallow near shore edge) I blew out the hose, and noticed water squirting straight down out the rudder bottom.
    The factory installed nylon plug in the rudder TE was missing !
    This is the hole that is plugged after drilling the waterchannel in the rudder. (see photo)
    Obviously this will decrease the cooling significantly .
    Not a big problem for me as I'm running with enough headroom temperature-wise, but for those already 'on the edge' this could cost you a motor or even worse if you use the single pick-up for the whole system.
    You might be, or might not be affected, but worth checking it.
    I solved this -and prevented a repeat- by tapping the hole with M3 thread, and screwed a nylon 3mm screw in a few threads with some medium CA, cutting the rest off.
    For those non-metric; 4-40 should work as well without drilling.
    Wisdom is knowing how little we know
  • carlcisneros
    • Jan 2010
    • 1237
    or you can use a dab of JB Weld and plug it up.
    • viper1
      • 219
      Agreed,
      Would be interesting to know if anyone actually found the same problem....
      • TristanJones
        • Oct 2012
        • 266
        Mines in the mail. Will let you know how I go
        • viper1
          • 219
          Sorry, I think I need to clarify; The plug was in there when it was new, just came out after 20 runs or so.
          • TristanJones
            • Oct 2012
            • 266
            yeah I got ya mate all good. I will get 20 runs through it in a week or so. I have too much spare time!
            • TristanJones
              • Oct 2012
              • 266
              Also check around the prop shaft, mine wasnt glued in well at all and was leaking quite a lot of water through there!!
              Easily fixed with some silicon or F/G resin.
              • viper1
                • 219
                Sigh, so lucky
                • TristanJones
                  • Oct 2012
                  • 266
                  viper1:
                  Id rather be working....
                  • viper1
                    • 219
                    Got a point there.
