What should I use inside hull on transom to add support for bolting rudder, strut, ect? Plywood? What thickness. Thanks!!
Transom support
I always use 3/32" birch ply, but just about anything would (wood?) work. Coat with epoxy. One thing to be carefull with is overtightening your hardware - the ply reinforcing piece, at least in my experience, will rarely perfectly flush up to the inside of the hull so when tightening the hardware, the hull moves inward and can crack.
just did this today starting a new build
before
after
DSC03712.JPG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
I do the same Tony and your caution notes are bang on.
Douggie
Originally posted by properchopper View PostI always use 3/32" birch ply, but just about anything would (wood?) work. Coat with epoxy. One thing to be carefull with is overtightening your hardware - the ply reinforcing piece, at least in my experience, will rarely perfectly flush up to the inside of the hull so when tightening the hardware, the hull moves inward and can crack.
before
[ATTACH=CONFIG]86911[/ATTACH]
after
[ATTACH=CONFIG]86912[/ATTACH]
