I've read through a bunch of threads, most were older. I just ran mine for the first time today, Leo 4082 1600kv, Seaking 180, (2)3s in series, M445 prop, hooked pretty bad in the turns. I saw one pic with an offset rudder, but not much feedback. What have people done to improve turning on this, as a single, what batt placement, props, strut depth....? Any input/feedback would be appreciated.
Delta force explorer single setup
My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Tags: None
Tucking the rudder with decrease the spinouts.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
I made an offset rudder bracket today, definitely helped. I will try tucking the rudder under a bit, thanks. Any more input is certainly welcome.My private off road rc track
I think this is a lot like my Shocker was/is.Tucking the rudder was the trick.It didn't take much but it holds the transom down in the corners.I tried small props but it didn't help.And playing with you're Expo and travel should help as well.
